Synthetic Oil Question
Old Jan 9, 2005 | 11:16 AM
REDRWUT's Avatar
REDRWUT
Default Synthetic Oil Question
i am considering going to Mobil1 in my Blazer. do i have to do anything special changing over from petroleum based oil to synthetic?
Old Jan 9, 2005 | 11:21 AM
90 droptop's Avatar
90 droptop
How many miles on the Blazer?
Old Jan 9, 2005 | 11:41 AM
REDRWUT's Avatar
REDRWUT
42000
Old Jan 9, 2005 | 11:43 AM
90 droptop's Avatar
90 droptop
No problem, just switch over on your next oil change.
Old Jan 9, 2005 | 11:44 AM
REDRWUT's Avatar
REDRWUT
thanks alot
Old Jan 9, 2005 | 12:29 PM
VetteTech81's Avatar
VetteTech81
Yep, you can mix them with no problems.
A While back in some seminars I have attended it was mentioned that on a higher mileage engine that has used dyno oil, after switching you may have oil leaks... I really don't believe this and if you do have a leak shortly after the switch it probably needed to be fixed anyway and was only band aided by sludge build up.
These new oils keep getting better and better..
-=Rick
To Synthetic Oil Question
