Interior lights not working properly
Old Jan 10, 2005 | 07:52 PM
murnutz's Avatar
murnutz
Default Interior lights not working properly
Good evening everyone! Recently I've run into a little problem with my interior lights. When I turn on the headlights the interior lights do not come on right away. They will come on after a few minutes of driving. Sometimes I can turn the lights back off and then back on, which will sometimes fix the problem. This problem does not happen all the time. Could this be a faulty switch? Perhaps a ground wire is loose? If it is a loose ground, where would I look for such wire? Any help would be greatly appreciated.
Murnutz
Old Aug 2, 2005 | 10:27 PM
steveC5's Avatar
steveC5
Sorry to bring this thread back to life, but I am having this issue right now and am curious on if you had found a fix or if anyone else knows the issue?
Basically the same thing. Turn on the car with no problems. Head lights come on with normal lighting. Only the interior lights do not. After a minute or so they come on at full strength with no dimming at all. Anyone know whats going on?
