Vararam Installed My Thoughts Inside!!!
Old Jan 10, 2005 | 08:38 PM
killaz's Avatar
killaz
Default Vararam Installed My Thoughts Inside!!!
wELL ups FINALLY SHOWED UP TODAY. TOTAL INTSALL TIME WAS 1.5 HOURS. I FOUND IT WAS A VERY EASU INSTALL. THE ONLY THING I CAN NOT FIGURE OUT IS, I CANT GET THE AIR BRIDGE TO SNAP DOWN IN TO PLACE ON THE RADIATOR COVER. THE AIR BRIDGE HUVERS ABOUT 1INCH OVER THE CLUPS. IF I PUSH DOWN HARD THEY WILL CLIP IN TO PLACE BUT POP BACK UP AFTER I LET GO. OTHER THAN THAT IT FIT WELL AND MY *** METER CAN TELL A NICE DIFFRENCE ABOVE 50MPH. ALSO SOUNDS COOL TOO
Old Jan 10, 2005 | 09:57 PM
VLVETTE's Avatar
VLVETTE
Try loosening all the clamps up top then clipping intake in place and lining everything up pushing the combination of clamps and connections together tighter then tighten. The box on mine wasn't closing properly and I could barely snap the intake in place. I didnt install mine to start with. But after I did as I said above she fit good.
Old Jan 11, 2005 | 01:11 AM
lowdowndirty's Avatar
lowdowndirty
Loosen everything up and readjust for the right fit. After everything fits right, tighten down the clamps. Chris
Old Jan 11, 2005 | 01:36 AM
quick99ls1's Avatar
quick99ls1
ok its time for me to buy VR.
Old Jan 11, 2005 | 02:32 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I wish I could hear this sound? I have heard that there is a unique tone or sound, but I have yet to hear it...a curious squid.
Old Jan 11, 2005 | 10:32 AM
VLVETTE's Avatar
VLVETTE
When I first got in mine after the install at LAPD I reved her a few times and asked Al what that sucking noise was. Funny thing it was coming from my wallet. Dam Mods!!!
Old Jan 11, 2005 | 07:51 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I wish I could have heard that sound everyone talked about with just the vararam. My gets all covered up in the headers and the GHLs :-()
Old Jan 11, 2005 | 08:16 PM
Phat Ride's Avatar
Phat Ride
Had some initial problems getting my air bridge to snap in place also, but if you invested in the Vararam definetly invest in a high flow air bridge(they won't have any snaps to hold in place). Definetly loosen everything up and work into the right fit and then re-tighten. Makes a nice horsepower increase for 3 -4 hundred bucks!
Old Jan 11, 2005 | 08:53 PM
ROMA 75's Avatar
ROMA 75
I just left mine without the little clips..it doesn't move....but i guess i have to try to unbolt .....do i want to do it..?
Old Jan 11, 2005 | 09:13 PM
SILVERTHUNDER's Avatar
SILVERTHUNDER
Cruising
CHECK POSITON OF MAF MAY NEED 360 DEGREES
Old Jan 12, 2005 | 12:14 AM
oufan2929's Avatar
oufan2929
I agree...I untightened and retightened everything and still could never get it to clip on. Then I rotated the maf a turn or two and they clipped right on
Old Jan 12, 2005 | 12:44 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Did you remember to remove the holders on the front frame for the stock airbox? If you left those in it will prevent the bridge from laying flat. Kaley
Old Jan 12, 2005 | 08:59 PM
killaz's Avatar
killaz
**** I FORGOT THE HOLDERS. O well its winter time in oregon and all i have to do is tare my car apart and put it back together. I will be a vararam install tech in no time at all
To Vararam Installed My Thoughts Inside!!!
