squeaky front end
Old Jan 10, 2005 | 10:20 PM
schnaker's Avatar
schnaker
8th Gear
Default squeaky front end
I was told by a mechanic it could be the front shock mounts. Anybody have this problem? How big a job to change them. 25,000 Miles on my 2000 coupe.
Thanks,
Eric
Old Jan 10, 2005 | 11:32 PM
motorokie's Avatar
motorokie
Sounds like sway bar might be squeeking. Check out thread on 1/8/05 on this forum.
Old Jan 11, 2005 | 05:42 PM
chriskaw7r's Avatar
chriskaw7r
Old Jan 12, 2005 | 04:29 PM
Griff2002's Avatar
Griff2002
The front end on my '02 is squeeking when it gets cold out. I'm trying to figure out if this is normal or if I should have it fixed while still under warranty.
Old Jan 12, 2005 | 06:09 PM
leaftye's Avatar
leaftye
It's an easy fix. If you have ramps, a 17 mm wrench, two 19mm wrenches, and a torque wrench with a 19mm socket, and some grease, you can easily do it yourself.
Eugene
Old Jan 13, 2005 | 11:02 PM
texasredc8's Avatar
texasredc8
Use Silicone Grease on the rubber bushings.
Old Jan 14, 2005 | 11:23 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
same problem here on a 2000
if i push down above the wheel well it does the same squeek i get going over bumps. Not sure what it is either, springs, bushings, or sway bar is my guess as well.
Old Jan 14, 2005 | 11:59 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
sway bar bushings are the most common problem, and they are the first thing to squeak in your suspension.
Do Not use any Petro grease. A silicone grease would work here.
Old Jan 14, 2005 | 12:34 PM
Face's Avatar
Face
I had a squeak in my rear suspension. After re-greasing the sway bar mid links, shock bushings, replacing shocks, it turned out to be a bad lower control arm bushing. Since the bushings are non-serviceable, I purchased one from Gene at Karshop.
Old Jan 14, 2005 | 01:12 PM
ericdwong's Avatar
ericdwong
I heard a good grease for rubber is John Deere Cornhead grease.
Old Jan 14, 2005 | 05:32 PM
leaftye's Avatar
leaftye
When you disconnect the endlinks, the bar should swing freely in the swaybar bushings. If it doesn't, grease and/or shim it until it does.
To squeaky front end
