Alright here we go. The heads are not milled and i did not check the quench. I just used the graphite head gaskets that MTI sent with the package. I have since been told I should have used the thinner gaskets.
I thought that 325/330 was pretty good on a 99 ls1. You have to remember that all 2001+ cars had the ls6 intake or else I would have been around 340-350 rwhp. I thought the baseline was great.
I guess it could be the injectors but i thought they were good for around 450 rwhp? Correct me if i am wrong.
I do not think the cam is the problem. I like the way it is designed and many other people use it. I find it odd that so many people are confused about the reverse split when this thing has been around forever. I am starting to think the heads are not all that great, but i definetly got an awesome power gain for the price I paid.
The more I think about it the happier I get with the car. Now i need to get a clutch so that I can launch it hard enough to get some solid times.
Thanks for all of the responses and the comforting. I know I will be happy for a while now that she spins to 6700 rpm
with everything above. What I would do next is go get some good scanner and wide band SW and do some highway and strip runs and see what she is doing really. A good check of AFR and you will see your timing and fuel tables intake parameters etc.
[QUOTEI guess it could be the injectors but i thought they were good for around 450 rwhp? Correct me if i am wrong. [/QUOTE]
I believe that both the 1999 and 2000 C5 LS1s had 26lb injectors. Check with Jason at Texas Speed and Performance for an unbelievable price on a set of brand-new GM (Bosch) 28.8lb injectors already mounted on a fuel rail. I believe these larger injectors were standard equipment on all 2001-2004 C5s and Z06s.
Here's the link: http://www.texas-speed.com/
Jason's number is 806-866-0734.
Good luck!
Ed
I only dynoed 388rwhp and ran 11.11 @ 121, so don't feel so bad.
That's terrific. I think the underlined problem is that people have unrealistic dyno expectations based on the forums. Every dyno is unique. Recently, I pointed out that the average H/C package didn't yield 440-470 rwhp.. People jumped in and said I was anti H/C, that I was out of touch with NA cars, etc, etc (all nonsense).. Stop worrying about dynos. Dynos can vary by over five percent, which in the case of the original poster would account to over 20 hp. If you want to know how fast your car is then take it to the track.
would 28# injectors really make that much of a difference at all?
Well, I'm certainly no expert but the 1999 C5 was rated at 345fwhp amd the 2002-2004 Z06 at 405fwhp. The 1999 and 2000 C5 had 26 lb injectors and the 2001-2004 C5s and Z06s 28lb injectors. GM must have thought the smaller injectors may run too close to a 100% duty cycle, and may max out, or probably wouldn't have changed them. You're putting down 405rwhp. You may at least be safer with the 28lb injectors, but can't answer your qeustion for sure. JMHO. Later
Ed
The 99 injectors are rated 26.2lb/hr at 4bar or 58psi. BLACKTOP2000 just put a set of 28.8lb injectors on his car making 415rwhp and 396rwtq and they were maxing to 108%. There is some left there though because his AFR went rich after 6K rpm's because the COT was left on. I think if you put a set of 28.8lb/hr injectors (get the ones from Texas Speed) that is what is on BLACKTOP2000's car you will be fine at your power level. Also you picked up 80rwhp. That's pretty good for that cam. If you just put your cam in dot to dot you may be a little more advanced than what the cam was ground to due to additive clearances and timing chain slop. You could get another 5-10 hp there, but your low end torque would fall off. Also, are you saying you still have an LS1 intake manifold on the car? If you put an LS6 on you could get much higher numbers because you are running a h/c. Put an LSX 78mm on there and you can see +20 over an LS1 intake.
The Vette Doctors told me that my stock injectors are working fine and I should only change them if I want to waste $$$. They told me that I wouldn't gain a thing. If the engine isn't starving for fuel there is no reason to change. At 405 RWHP and 385 RWTQ I'm not complaining.
When I did my H/C package I was wanting to hit 400rwhp SAE corrected or get very close, when I ended up at 413 I was thrilled.
I have a pretty small cam and my LS6 heads were massaged to about the equal of the MTI ones you got. I did however go to the 28# injectors just to avoid any future problems. I know if I want any more power I'm really going to need a bigger cam.
I do plan on going to a Z06 MAF and throttle body and I'm really hoping I gain a little there but I bet its not all that much. I would be very happy if I could just hit 420rwhp SAE corrected.
verify the injector cycle duty and you will know if they are adequate.
it would be nice to see your dyno run posted.
if you have it where does the hp curve start to drop off?
is the line jumpy at the upper RPM?
I have the dyno graph but no way to get it on the forum at the moment. The torque curve is pretty flat and the horsepower graph is smooth. The curve peaks around 6500 and there are no signs of problems. AFR is almost solid @ 12.8
Another thing I forgot to mention... Andy @ 21MC was able to add 31 degrees of timing and still had NO knock or detonation. That led us to believe that the compression was low. We only did a leak down test as I said above and everything came out alright. How did we get that much timing into it and not knock?
the only item I see then is the compression.
I installed stage 2 ls6 heads on my car and I requested no milling(they were new blanks).
my tuner said I gave up some HP by not bumping the compession up to
11 or 11.5
I have the X1 cam, stage II heads, headers, fast 78 intake and am putting down 402 rwhp 368 ftlbs of tq. So you are not too far off. I felt like you tho, and thought I would put down close to 420. I have some tweaking left to do, but it still does kicks ***.
The 21MC guys did everything to try and make me happier with dyno tricks and all but nothing.
Did they actually tell you they were going to use "Dyno tricks"?
That implies they were going to play with something on the dyno to get it to give a false high reading so you could have a good chart? Or am i reading that wrong?
Dont get me wrong... After we got all the good dyno sheets together that were perfectly fine we did things like air up the back tires a little more and make sure the tranny was good and warm. It was nothing. I was just trying to give props to the guys for doing a good job and trying to cheer me up
