Question on Head Unit/CD Changer/iPod???
Old Jan 12, 2005 | 10:28 AM
MHVette's Avatar
MHVette
Default Question on Head Unit/CD Changer/iPod???
Question - I have a 2000 Coup with the Delco/Bose Head Unit and was wondering if a wire was already prerun from the Head Unit to the CD changer even if you/I don't have a factory changer. I'm thinking of connecting my iPod to the head unit directly so I don't lose any clarity. (Here is a link if anyone else is interested http://peripheralelectronics.com/ipod2car/index.shtml, I think monster cables is making one as well but they are for 03 or newer vehicles) I currently play music from my iPod using a FM Transmitter but it doesn't compare to the quality of a CD. If I have to remove the dash to get the head unit then so be it, but I would much rather use an existing prerun cable! Thanks for any help!
Old Jan 12, 2005 | 11:28 AM
MHVette's Avatar
MHVette
I know someone knows Anyone???
Should I post this in somewhere else???
Old Jan 12, 2005 | 12:17 PM
ersatz928's Avatar
ersatz928
Search the forums, Audio and Electronics. I recall that someone said that some cars (Earlier model years) have the cable, but later ones do not (If no changer option from the factory)
Old Jan 12, 2005 | 03:27 PM
RCK1999's Avatar
RCK1999
I believe that all cars came with a jack in the harness located under the passanger dash. The stock location for the CD changer is in the center rear compartment. If you did not get the CD changer stock, then there IS NO harness from the footwell to the back compartment. So I think the answer to your question is no, you don't have to break into the dash to find the connection.
Old Jan 12, 2005 | 04:34 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
you might need this GM-AUX10 with this http://forums.corvetteforum.com/show...=changer+aux10
Old Jan 12, 2005 | 11:22 PM
markcz's Avatar
markcz
You would need to get a CD-Changer Wiring Harness to plug into the passenger floor board connections and a GM10-AUX - GM Digital auxiliary input converter to to convert the changer plugs into an RCA input. FYI, the site I linked to is Tuan Le's, and Tuan is THE MAN.
I used both of those and more in my car, you can read about it here.
Old Jan 13, 2005 | 09:24 AM
ThissenW's Avatar
ThissenW
I suggest you check Ebay for the protocol converters. They're often available used at half price.
Old Jan 13, 2005 | 09:37 AM
MHVette's Avatar
MHVette
Thanks to everyone who replied! You've all been a great help!
Old Jan 13, 2005 | 03:20 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I just removed the 12 disk changer to install a sirius satellite radio in my car, I am using the GM10-AUX interface and it sounds great.
controller is mounted in the ashtray area.
Old Jan 13, 2005 | 06:18 PM
fdxpilot's Avatar
fdxpilot
Also, since you want to hook up an IPod, you may be able to cut out some of the harness (it's 6-8 ft long to get around the rear compartment, to the center well) and mount your IPod somewhere up front. Just a thought.
To Question on Head Unit/CD Changer/iPod???
