Optima/Battery Tender Question...
Old Jan 13, 2005 | 03:45 AM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Default Optima/Battery Tender Question...
I bought a battery tender today. I was surprised to see that EVERY tender I looked at (went to 4 stores) had a statement on the box that said "for use on Lead/Acid batteries only."
I can't believe that you can't put a tender on a Red Top.
Why do they make this statement? Is there an issue with using a tender on a gel-cell? Or, as I am guessing, they are differentiating a lead/acid battery from a dry cell?
Old Jan 13, 2005 | 08:22 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
ummm The Optima is still a lead acid battery - need the reaction to make the power right? The battery is just "sealed"
Old Jan 13, 2005 | 08:24 AM
rwlc5's Avatar
rwlc5
I have used the Battery Tender on my Red Top for three years with no problems.
Old Jan 13, 2005 | 08:54 AM
YO-EL's Avatar
YO-EL
You have to get a special Battery Tender for the Optimas..
I called up Battery Tender people, and they told me they make 2 types.
I think its something about the charge rate or something they did when its going to be used on a spiral cell battery..
Cost was the same.. I'll try to shoot a pic later on tonight or give a model #..
Old Jan 13, 2005 | 09:11 AM
wrustywrench's Avatar
wrustywrench
I have the battery tender hooked to mine , no problems for two years. Dint know they made two types
Old Jan 13, 2005 | 09:52 AM
C5 Frederik's Avatar
C5 Frederik
same here, no problem
Frederik
Old Jan 13, 2005 | 11:38 AM
RoHo's Avatar
RoHo
Same here, I have had one connected to the Optima in my Hot Rod for over five years, no problems
Old Jan 13, 2005 | 04:07 PM
2KREDVert's Avatar
2KREDVert
[QUOTE=RFJohnston]I bought a battery tender today. I was surprised to see that EVERY tender I looked at (went to 4 stores) had a statement on the box that said "for use on Lead/Acid batteries only."
I think you are confusing a "Lead/Acid" battery with a "Flooded Type" battery. There a three kinds of Lead/ Acid batteries: Flooded (Most Common), Gel (Sealed), and Absorbant Glass Mat (Optima).
Old Jan 13, 2005 | 06:47 PM
wwashing's Avatar
wwashing
[QUOTE=2KREDVert]
Optimas are not a Glass mat battery, they are Spiral Cell batteries. I've used a general purpose Automatic Charger on my Red top for 5 years, and my Battery is fine.
Old Jan 13, 2005 | 08:15 PM
2KREDVert's Avatar
2KREDVert
[QUOTE=wwashing]Optimas are not a Glass mat battery, they are Spiral Cell batteries.
They are still a glass mat type as far as charging properties are concerned, just spiral wound instead of laid flat. They are not flooded or gel.
Old Jan 13, 2005 | 09:28 PM
YO-EL's Avatar
YO-EL
The model I have is 022-0071
Looks like its now replaced by model 022-0157.
By the technical info, it looks like my 0071 model may be a little bit stronger/better??
See page 5 for the comparison to my older 022-0071 model...
http://batterytender.com/includes/la..._Info_LWOB.pdf
Old Jan 13, 2005 | 10:33 PM
Rickk's Avatar
Rickk
I have a battery tender plus that I ordered from http://www.batterytender.com On the back of the package it says " The Battery Tender Plus will correctly charge and maintain any type of lead-acid battery-AGM(absorbed glass mat), sealed calcium or gel batteries. I have it hooked up to a Redtop. No problems with it.....The model number I have is 021-0128.
Old Jan 14, 2005 | 10:20 AM
RPOZ16's Avatar
RPOZ16
Just bought two new ones and they are model #021-0128
Battery Tender Plus
To Optima/Battery Tender Question...
