If my car is getting tuned on a dyno that is located at 800
feet above sea level and I plan on running at a track that is
located at 300 feet above sea level how much will my A/F ratio
change at WOT ?
change at WOT ?
Thanks >>>>> INTHERED
Shouldn't change much at all. Day to day barometric and humidity changes can be a bigger variable than what you mentioned. The mass air flow sensor reads and the CPU adjusts.
Yeah, not much change at all. I get more elevation change on my 20 minute drive thru city traffic to work. I can't report times, but my butt dyno only notices differences with 5,000 ft elevation changes.
The change in WOT A/F for my car from sea level to 5,500 ft was only 2%. Small changes like you are talking about, the car will compensate for perfectly, you'll see no change.
