Brake Bleed
Jan 19, 2005 | 12:58 AM
Brake Bleed
Anything I need to know about bleeding my brakes after all 4 calipers are changed. I have the speed bleeders.
mrgil
Jan 19, 2005 | 01:12 AM
St. Jude Donor '09
donot bottom out the brake pedal when bleeding
Jan 19, 2005 | 02:10 AM
Jan 19, 2005 | 02:18 AM
Cruise-In V Veteran
St. Jude Donor '04
In case you don't know the sequence it's
right rear, left front, right front then left rear
Jan 19, 2005 | 03:26 AM
Isn't it RR LF LR RF for 2001 an newer?
Jan 19, 2005 | 04:00 AM
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
I've always done furthest wheel from the master cylinder to the closest... That's what really matters.
Jan 19, 2005 | 08:53 AM
Quote:
In 2001 GM changed from manual to elctronic proportioning. They changed the bleed sequence from the traditional RR LR RF LF (Furthest to the closest) to a diaganol RR LF LR RF.
Jan 19, 2005 | 09:52 AM
So, what would be the sequence for the 2000 coupe?
Jan 19, 2005 | 10:30 AM
Hello,
I have never read about not bottoming the pedal.
Can someone enlighten me about this method?
Jan 19, 2005 | 10:48 AM
Quote:
Traditional RR LR RF LF
Jan 19, 2005 | 11:38 AM
Quote:
Originally Posted by Kenny94945
Hello,
Neither have I! But then again just go get one of those vacuum pump bleeders, they work great. Just make sure the resv. stays full. I usually give the back side of the caliper a bump with a short piece of 2
X4 to get the bubbles out. Then rebleed about a week after driving around.
