ABS Active? What the?
Old Jan 19, 2005 | 08:59 AM
6Speeder's Avatar
6Speeder
Default ABS Active? What the?
I had some ricer pinhead tailgating me on the freeway, so I did a full throttle downshift to third, to gain some distance (OK... and cause it's fun!). The car accelerated normally (i.e. raped ape) but the DIC switched to the message: ABS ACTIVE for a second then resumed normal data. Usually when I break traction the traction control message comes on, never this. Any clues?
Old Jan 19, 2005 | 01:00 PM
Antivenom 447's Avatar
Antivenom 447
2 questions..... Do you have an aftermarket brake kit and aftermarket wheels that are oversized from what was placed on the car? I have both of the above and had my car do the same thing and lock up on me under normal driving conditions without my foot even being on the brake. I'm still trying to figure that one out. I bled the ABS block and the brakes and no problems since. If I find any other info I will let you know. Good Luck!
Old Jan 19, 2005 | 02:51 PM
6Speeder's Avatar
6Speeder
My brakes are stock, I do have different sized wheels/tires than stock...But they haven't been a problem for the last 4 years :o My TC and ABS allways seem OK.
To ABS Active? What the?
