PLEASE HELP!!: Electrical Problem
Old Jan 19, 2005 | 10:00 PM
wdhille's Avatar
wdhille
Cruising
Default PLEASE HELP!!: Electrical Problem
On my 99 C5 I have two intermittent electrical problems, I hope somebody has a clue. I've been to the shop (Criswell in Gaithersburg MD) and this morning they said it could not be duplicated. I get in the car and it fails.. I don't want to leave it at the shop for days, so I'll try and figure it out.
1) The horn will not honk from steering wheel. It will honk with the remote alarm, so it tells me the rely and horn are OK. Any clue where the harness goes? Sometimes it works.
2) The right side window works fine from the right side. It is intermittent from the drivers side, but always works from the passenger side.
I can do nothing to correlate either of these, I can tap on them, bang on them, drive over bumps, and I can't make it happen or not happen. It just sort of has a mind of its own. There are no error codes when I check the codes.
Thanks if anybody can point me in the right direction!
Wayne
wayne@flymha.com
Old Jan 19, 2005 | 10:14 PM
imagine32000's Avatar
imagine32000
Wayne
wayne@flymha.com
If the horn beeps everytime you remotely lock the car, then I would inspect the switch/relay on the steering wheel. Your 2nd problem, I would inspect the wiring harness/end connectors behind your driver's side door. Good luck.
- Matt
