KOOKS 1/78ths NIghtmare HELP!!!!
Old Jan 20, 2005 | 01:19 AM
smokenuz06's Avatar
smokenuz06
Default KOOKS 1/78ths NIghtmare HELP!!!!
Well as the title says I am trying to install the Kooks 1/78th on my 02 Z06 and I got the drivers side on but I cannot get the passenger side on I have even taken the motor mount off and pushed the motor over. Has anyone else installed these if so PLease help. Thanks
Old Jan 20, 2005 | 04:04 AM
ditty22's Avatar
ditty22
ttt 4 u!
Old Jan 20, 2005 | 05:30 AM
99blackFRC's Avatar
99blackFRC
Installed a few sets of these.. but all with the heads off. I've always just removed the motor mount bolt and jacked up that side to get them in.
Old Jan 20, 2005 | 06:20 AM
78Vette-SA's Avatar
78Vette-SA
On some occasions I have had to remove coil packs and valve covers, starter (don't need to disconnect the wires just remove bolts and shove out of the way), and then jack up the engine. Car has to be up in the air far enough to drop the header down, jockey it around.
It will go.
Old Jan 20, 2005 | 07:06 AM
Patches's Avatar
Patches
We took the coil packs, valve cover and starter off as well to fit the passenger header in. I helped install a set of 1-3/4" Kooks so the clearance was probably slightly better. We definitely had to jack the engine to get enough clearance to drop the header in.
http://www.redshift.homestead.com/kooks.html
Old Jan 20, 2005 | 08:29 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Call me if you still cant get them in.
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Jan 20, 2005 | 09:03 AM
purrvert's Avatar
purrvert
took off everything including valve covers, loosen opposite motor mount, remove nut from pass side mount, jack eng up from pass side till intake barely touches cowl, at least loosen starter ( best to remove and don't forget to reinstall before landing headers ) they will go in. May have to pry engine over with a 2x4. The instructions really oversimplify the job but it can be done.
Enjoy the response the Kooks will give you.
Old Jan 20, 2005 | 09:28 AM
ragtopws6's Avatar
ragtopws6
Here you go, this is what I used to install mine.
http://www.z06vette.com/forums/showthread.php?t=54052
Old Jan 23, 2005 | 03:28 AM
smokenuz06's Avatar
smokenuz06
Thanks for all the help guys.Finally got them in tonight. I know I'm new on here but everyone is so nice and helpful. I do apprciate it for the newbie. Thanks again guys.
Old Jan 23, 2005 | 05:55 AM
pdd000's Avatar
pdd000
happy that you resolved the issue
To KOOKS 1/78ths NIghtmare HELP!!!!
