Performance upgrades?
Old Jan 20, 2005 | 11:53 PM
elev84u's Avatar
elev84u
Cruising
Default Performance upgrades?
I have just started upgrading my 2002 coupe. I put a K&n Air filter on. Does anyone have an opinion of what upgrades i should do first? You know what would give me the most bang for the buck? Thanks for any insight. Also any recommended manufactors
Old Jan 21, 2005 | 12:14 AM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
Generally intake and cat back exhaust systems are the first mods.
Borla and GHL make great sounding systems. I did the Blackwing intake and GHL magnums on my 2002 A4 coupe and loved them.
Best bang for the buck in the performance dept is usually changing gears. Then you can go headers, head/cam .....blowers.....there are lots of ways to spend mod money on horsepower.
Old Jan 21, 2005 | 12:29 AM
Phat Ride's Avatar
Phat Ride
Is your coupe a 6 speed or auto? what rear do you have in it?
Old Jan 21, 2005 | 12:36 AM
agripp's Avatar
agripp
Default Performance Mods
I have done the following mods - Vararam with smooth coupler, 3.42 rear, 160 degree thermostat & ZO6 titanium exhaust.
I would put the Vararam/smooth coupler as a first choice as it produced a lower ET & higher MPH at the track than previously recorded.
2nd choice would be the 3.42 gears & the 160 thermostat. This made the car quicker in general but was the most expensive to do. I started with 2.73 gears, so by doing the 3.42s & the thermostat at the same time I was able to have both items reprogramed at the same time (with no codes thrown).
Lastly the ZO6 Ti exhaust is lighter than the stock exhaust and sounds better under acceleration. I didn't want anything too loud.
The order of these options is what I would suggest, even though I did them in the reverse order.
I race on stock run flats & my first times/mph were 13.7/103+, I worked that done to 13.3/105+, but when the Vararam was installed my first run was 12.96/107.5. So, I feel I received the most bang for the buck out of the Vararam cold air intake. I would recommend that you install the ZO6 front screens, they not only look nice but they prevent the ingestion of debris & especially small leaves in the Fall.
It would help if you let members known if your car is a 6 speed or automatic & what gears.
Old Jan 21, 2005 | 01:18 AM
elev84u's Avatar
elev84u
Cruising
Soory about that its a 6 speed w/2.73
Old Jan 21, 2005 | 01:56 AM
Phat Ride's Avatar
Phat Ride
I have to agree with the last reply, the Vararam intake is by far the best bang for your buck! I wasted money on a different intake similar to the dual cone K&N I assume you are referring to. Vararam is the way to go, I have Magnaflow cat back, it is very mellow at idle and sounds good under throttle but not real aggressive, so if you want loud muscle car sound there are better choices. High flow air bridge and coupler are a must with aftermarket intake. I'm scheduled to go to E.C.S. in Jersey tommorow to have them install Kooks headers and a dyno tune. Hopefully the snow holds out!
Old Jan 21, 2005 | 07:32 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
LGM headers and a cam
Old Jan 21, 2005 | 07:54 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
You may be little better off than you think... I thought the MN6 had the 3.42 rear?
Old Jan 21, 2005 | 08:03 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Mine does, and that is why I'm putting in 4.10s in two weeks!
Old Jan 21, 2005 | 08:57 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I would add the Z06 sway bars to your list. Inexpensive way to improve the handling of your car.
Old Jan 21, 2005 | 09:05 AM
vetteamerica's Avatar
vetteamerica
All six speed C5's come with 3.42 gears.
Some Free mods = gut cats, remove mass air sensor screen, throttle body bypass.
160 stat good set mufflers.
To Performance upgrades?
