HELP...Zero Oil Pressure @ cold start-up...
Hoping one or two of you might have encountered this rather strange oiling dilemna...
On cold start up, the engine shows zero oil pressure (both guage and DIC) and usually stays at zero for a couple of minutes. (Yes, I already replaced the oil pressure sending switch behind the intake). Whats strange is that the engine isn't any "louder", the valvetrain isn't clacking away which you would expect, and usually when I pull out of my driveway after warming it up for a minute or two, the guage slowly creeps up and shortly thereafter will read normal while I am driving it around. Once the car is hot, if I go back and re-start it, the oil pressure seems "normal" and I don't seem to have any issues.
I replaced the sending unit last night which I was hoping would cure my problem but the guage is acting exactly the same. Sitting there with the car runnning displaying zero oil pressure for a few minutes is anything but confidence inspiring....I'm wondering if I spun a main bearing which isnt allowing oil pressure to reach the sending switch area, but yet I'm still getting pressurized oil to the lifter galley therefore no valvetrain noise when the guage is reading zero.
Any thoughts or suggestions???
Thanks,
Tony M.
PS Might try cutting the oil filter open this weekend to look for some bearing debris....obviously hoping that's not the case, but I can honestly say that this engine doesn't owe me a dime...
Phil
Very weird...
You should trust that you really dont have oil pressure, that its not a gauge or sending unit messing with you. The way it is acting is a lot like a case I had on a customer's car not too long ago: a small piece of debris was caught up in the oil pump, effectively shimming the main oil pump rotor from the sidewall, allowing it to lose its prime. It was the damndest thing I've ever seen. By the time I found this problem, I had done everything from drop the pan and check the bearings to blow out all oil galley's, new sender, etc. The debris was a collateral effect of piston damage he sustained a month prior from a failed valve spring allowing the valve to punch a hole in the top of his piston. A small piece of debris the size of a pencil lead tip worked itself loose from a nook or cranny of the motor a month later and sideloaded in the oil pump. He had the exact same symptoms as you- with no valve train clatter or any other sign of not having oil to his valvetrain. Just a suggestion from my own experience.
robert / gen 3 ms
robert / gen 3 ms
There has to be SOME oil moving thru the motor or how could the lifters not collapse and make a racket?
I definately appreciate your input...I might have to pull the shortblock when I do the 225 install....looks like I might be needing a freshen up!
I'm going to cut open my oil filter tonight and check it for signs of any bearing material or other "unwanted" debris.
I think I might have an "oil priming" issue as Rob had suggested....I was just hoping there might be an easier solution.
Looks like I might be laying up the car a liitle sooner than I thought for the 225 install.
Thanks,
Tony
I did a leak down and the worst hole was slightly more than 2%....outstanding all things considered (50K on the stock GM shortblock). The other thing I did was fabricate a billet adapter to replace the GM oil temp switch on top of the filter pad....I tapped it for eigth inch pipe thread and ran a line to a mechanical pressure guage. At this point I'm hoping there is something funny in the computer which processes the information from the sending switch but I'm not holding my breath. I have a feeling its a "priming" issue and I will probably have to get to the pump to address that.
Final chapter on Saturday....have to re-adjust my rockers and get the car back together to fire it up and see what the mechanical guage reads.
Maybe it fixed itself when I changed the oil and filter tonight.....
Fill all of you in over the weekend sometime.
Tony M.
It sounds like you have a pretty good idea what it is and I'm willing to bet an oil pump is in your future, just consider thats alot easier on the wallet than a spun bearing
OK before I get pounded, that was a joke. get it ha ha
I think its the oil pump going. Ill throw in a guess like everyone else
The right guess gets a new set of AFR 225's
Im glad you understood it was a joke. I was affraid a nut on here was going to bash me.
I did enjoy your responce
Did you figure out the problem yet?
After finishing up the leak-down test and running the line for a mechanical guage, I let the oil drain all night with the car on an incline so to get every drop of old oil out of the pan. I then proceeded to re-adjust all my rocker arms (Crane 1.7), install new oil and filter, and basically just put her back together so I could fire it up and check the mechanical guage reading against the factory instruments.
Turned the key and it fired to life fairly quickly with a bunch of clatter from the valvetrain (briefly) as the oil pressure had to fill all the oil gallies, new filter (which I always pre-fill), and pressurize etc...normal stuff when draining the oil completely and changing the filter. A second later or so the clattering of the valvetrain quieted right down and the mechanical oil pressure guage as well as the one in my car are quickly swinging up to 40 PSI....just like normal.
I let the car sit for a few hours so it was good and cold again, tryed re-starting it and everything seemed normal again (no clatter from the valvetrain this time as the lifters were already filled with oil). Took her out for a nice drive and parked it back in the garage last night.
So know I'm left with two thoughts....
1) What did I do that "cured" the problem (assuming nothing changes)?
2) The lifters briefly clattering till the oil got thru the engine tells me that if I really had ZERO oil pressure previously, it would make sense that the valve spring pressure would have bleed them down and they would have been making a racket if in fact it was idling with no oil pressure.
Very weird....but I'm glad things "seem" to be back to normal. I'll follow up in a week or two and let you know how things go.
Thanks to everyone who took the time to write and make suggestions...
Tony M.
I still think something was clogging the line or pump
Im glad it is nothing major. We alway think worst first.
The pressure relief will get stuck open thus causing the low oil pressure. There is some pressure, 5 or7#s, enough to float the crank, but just enough to make the PCM go haywire.
Tell me what year that pump is off of, and I will let you know if you should worry
Louis
Louis
How's it going?
The pump is the stock pump that's been in the motor for 50K. My car is a 2000 model, but it was literally built the last week before the plant commenced building the 01's, so it could be either. When I do the 225's soon I will probably switch it out just to be safe.
Thanks,
Tony
I would swap it when you do the 225s
Louis
..the other day my stock '98 (50K miles) did the exact same thing....both the gage and the DIC said zero pressure..
..scared me to death. So I shut it off and immediately checked my oil and everything seemed fine...started it up and listened for the valvetrain rattle and none and so got back into the car and by then the oil pressure gage started to come up finally. It happened just that one time and never done it since, so I've been curious what it could have been.
John
