Zo6 vs. Z51 Sways
Old Jan 21, 2005 | 07:57 PM
Too Slow '90's Avatar
Too Slow '90
Default Zo6 vs. Z51 Sways
Is there any difference? I have a '98, can I install '99 Z51's? What other pieces do I need? Thanks.
Old Jan 21, 2005 | 09:15 PM
skip89's Avatar
skip89
When I had my 98 cp I put the 2002 ZO6 front and rear sway bars on my base suspention car. I got the setup from Fichtner here on the forum. It comes with metal end links, stock ones are plastic, and new rubber sway bar gromets. Every thing you need. It made a wonderful difference with flatter, more controlled cornering and much better steering feel. The ride stayed good as before because I did not change shocks. Now I have a 04Z and I would recommend you put 04Z shocks on your car with the sway bars. Very good mod. Good Luck, Skip
Old Jan 21, 2005 | 09:24 PM
66427-450's Avatar
66427-450
as Skip said...... z06 and z51 rear bars are the same, the z06 front bar is a bit bigger in OD, and thicker, than the z51 front.
Old Jan 21, 2005 | 11:02 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I have a set of Z51 bars that I would sell to you. Let me know if you are interested.
VR
Old Jan 22, 2005 | 02:04 AM
C5tx's Avatar
C5tx
Yes, there's a difference. The '99 Z51 front and rear bars are
slightly smaller than the Z06 front and rear bars (the '00+ Z51
rear bar is the same as the Z06 rear bar). You'll need the matching
bushings (insulators) for the bars you decide to use. You should also
upgrade the cheap plastic end links.
You can install the '99 Z51s but, as others have recommended, I'd go
with the Z06 bars and the '02+ aluminum end links.
To Zo6 vs. Z51 Sways
