Service ABS and Trac Control
Old Jan 25, 2005 | 07:43 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Service ABS and Trac Control
Been driving on ice, snow, and salt.
These messages are coming on occassionally with the ABS symbol and the Trac Control symbol.
A mamber on General said disconnect the connectors at each wheel and clean.
Was under there last night as best I could and could not find out where the connectors are.
Does anyone have pics?
Easily reset with the RESET, but has appeared 3 times.
Old Jan 25, 2005 | 09:22 AM
jthoresen's Avatar
jthoresen
I've done this; I'll try to send pictures... First get the DIC code, this will tell you what wheel is the problem… You need to remove the rim, then on the back side of the hub you can disconnect the 2 wire plug, clean and try again, if this dose not resolves the issue, you’ll need to replace the hub, (wheel speed sensor is a part of the hub). I can also send pictures / diagrams. The hub is very expenses, but I got a new one off of ebay cheap.
Old Jan 25, 2005 | 05:40 PM
d55guy's Avatar
d55guy
but also check the wiring going to the WSS. Mine had come loose and rubbed against the rim. It took of the insulation off and would make intermediate contact and cause the codes. A quick wrap of electrical tape took care of it for now.
Old Jan 25, 2005 | 07:09 PM
Robiwan's Avatar
Robiwan
Check for DTC codes and if they are present, it will help you in determining the problem.
To Service ABS and Trac Control
