Is an alignment necessary?
Old Jan 25, 2005 | 12:11 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Default Is an alignment necessary?
Swapping existing tires with 5000 miles on them onto new wheels. These are the stock tires on stock rims swapping to the same size new rims. Is a front and rear end alignment necessary to or not? The place I am swapping the tires at strongly recommended I do the alignment. Thanks for your input.
Old Jan 25, 2005 | 12:19 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Nope. Sounds like they are trying to screw you. Take it somewhere else and tell them to stick it up, well you know. (Assuming your alignment is fine now.)
Old Jan 25, 2005 | 02:26 PM
allanlaw's Avatar
allanlaw
Alignment, NO. Of course, balance YES.
Old Jan 25, 2005 | 06:05 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
It amazes me what some people will tell you need to have done just to make a few bucks.
Old Jan 25, 2005 | 08:20 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
not necessary to align just because you are switching wheels. but when is the last time you had one done? just did one on a Z06 today with 16k on the clock. camber on left side was way out of specs front and rear.
Old Jan 25, 2005 | 08:24 PM
debmwb's Avatar
debmwb
only if you have unusual wear.
To Is an alignment necessary?
