C5 Corvette Lower Front Spoiler Replacement Kit
Platinum Supporting Vendor
C5 Corvette Lower Front Spoiler Replacement Kit $90.20 With Code PHIL5 At Checkout
These C5 Corvette Front Spoilers in urethane give your Corvette a factory-fresh appearance and restore proper air flow through your radiator, solving many cooling problems. Our C5 Corvette Front Spoilers mount in the factory locations. You can use your original hardware but if it is missing or damaged you can add a hardware kit below.
Since the front spoiler is a 3-piece design the centerpiece is spring-loaded and can bounce right back in place, however, the left and right sections are not, which means they could rip off altogether if you hit a bumper block or curb. A nice upgrade to alleviate this, we introduce the Corvette Spoiler Reinforcement Kit part # C5607033 (Sold Separately). These black, ABS plastic brackets take the brunt of a bump and prevent bolts from sliding through, keeping your spoiler securely in place. Kit includes one left and one right bracket and installs easily using existing fasteners.
This spoiler kit will fit 1997-2004 C5 Corvette, including base, coupe, convertible and Z06.
http://www.rpidesigns.com/shop/item.aspx?itemid=1905
C5 Corvette Front Spoiler Reinforcement Kit $19.99
Your 3-piece spoiler centerpiece is spring-loaded and can bounce right back in place, however, the left and right sections are not, which means they could rip off altogether if you hit a bumper block or curb. To alleviate this, we have the Corvette Spoiler Reinforcement Kit. These black, ABS plastic brackets take the brunt of a bump and prevent bolts from sliding through, keeping your spoiler securely in place. Kit includes one left and one right bracket and installs easily using existing fasteners.
Fitment: 1997-2004 C5 Corvette, including base coupe, convertible and Z06.
http://www.rpidesigns.com/shop/item.aspx?itemid=1908
Corvette Forum members save with promo code PHIL5 at checkout
This is a very important part to get in air to Radiator to your C5 Corvette to keep it running cool, if it is damage or missing your car will not cool properly and should be replaced.
