Brembo 97-04 Corvette Front 6-Piston Monoblock | 355x32 mm (14")
Former Vendor
Brembo 97-04 Chevrolet Corvette Front 6-Piston Monoblock | 355x32 mm (14")
https://www.xplosiveperformance.com/...illedorSlotted
Product Description:
(F) 6-Piston Monobloc Calipers | 355x32mm (14') 2-Piece Discs | Complete Axle Set | Pre-Assembled | All Necessary Hardware Included
Caliper
Caliper Body: Cast Monobloc Radial Mount
Caliper Piston Configuration: 6-Piston
Caliper Piston Design And Insert Type: Inner Pressure Seal / OEM Approved Dust Boot
Disc
Disc Type:
Cross Drilled
Slotted
Type 3
Disc Material/Finish: Advanced High Carbon Alloy / Corrosion Resistant Plating
Disc Diameter: 355mm
Disc Width (Measurement): 32mm
Disc Air Gap (Measurement): 16mm
Disc Annulus (Measurement): 54mm
Disc Construction: 2-Piece Disc Assembly
Disc Vane Design (Measurement): Vented Curved 48 Vane
Disc To Hat Mounting System: Floating D-Bobbin with Anti Rattle Spring
Friction Material
Pad Compound: Brembo High Performance FM1000
Pad Volume / Surface Area: 94.5 | 84
Included Hardware
Brake Lines: Proprietary Brembo Stainless Steel Braided Brake Lines by Goodridge
Mounting Hardware: Brembo Engineered CNC Billet Caliper Adapters - All Necessary Hardware Included For Ease of Installation
Check Wheel Fitment uses 18" wheels
Caliper
Disc
Disc Type:
Cross Drilled
Slotted
Type 3
Friction Material
Included Hardware
G_Loc (10-20-2022)
Received 19,586 Likes
'20-'21-'22-'23-'24
Moved to C5 Vendor for Sale section to comply with the maximum number of threads on the first page of a two day directory.
