[Z06] Build date and sequence number
Hey guys, can anyone tell me where/how I can find the build date and the production sequence build number of my 2002 Z06. I went to the NCM website and I can get a build sheet from there but I don't think it will tell me what I need to know. I know you can tell the sequence in the TOTAL production run but not the Z06 specfic run. I purchased the car new in Aug. 2001 so I know it will have a low production number. Thanks for any help you can give me.
The Z06s were mixed in with the general production so the only way I know to get the Z06 specific production numbers is to get a list of the complete production records for 2002 and go through it and pick out the Z06s. As far as I know nobody has done that yet. GM tried to do that for us 2004 Z16 Z06s guys but screwed it up. Someone in our group had a dealer friend and they completed the list.
Good luck with your quest.
St. Jude Contributor
Join the C5 Registry
Your production number is your last six (6) digits of your VIN #. My 2001 Z06 is 134934 which was on the floor June 18th 2001.http://forums.corvetteforum.com/newr...1&p=1573009787
What advantage does a singular Z06 production time line give you? Compare your last six digits with any other Z06 and the sequence is established. Now as for myself , I would like to know how many other Z06es were completed before that 2001 M/Y ended on the 21st of June 2001
I obtained the build date of my 02' Z06. It first fired to life on Aug. 14, 2001. Now I need to find out how mant Z06's were produced in the month of August, 2001. Can anyone tell me where to find that information?
Here is the info on your vehicle.
VEHICLE INFORMATION
Merchandising Model : 1YY37 -2002 CORVETTE Z06 Warranty Start Date : 08/23/2001
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : KERBECK CADILLAC PONTIAC CHEVROLET, INC.
430 N ALBANY AVE
ATLANTIC CITY , NJ 08401-1315
(609) 344-2100
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/10/2001 055962 # N3590 - SWITCH, WIPER MOTOR PARK - WINDSHIELD - REPLACE 1296 miles
08/14/2001 A03715 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1613 kg (3557 lb) Order Number : DMJS9R
Build Date : 08/14/2001
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE4 - RIDE & HANDLING SUSPENSION SYSTEM GU6 - REAR AXLE 3.42 RATIO
IP4 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
NC1 - CALIFORNIA EMISSIONS LEV NC7 - FEDERAL EMISSIONS OVERRIDE
NG1 - 50-STATE LOW EMISSION VEHICLE NK4 - LEATHER WRAPPED STEERING WHEEL
P12 - CAST ALUMINUM WHEEL R6M - NEW JERSEY COST SURCHARGE
R9Z - POMS EXPEDITE - SOLD ORDERS SLL - SOLD ORDERS
UN0 - AM/FM STEREO W/CD PLAYER UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U73 - FIXED MAST ANTENNA
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFW - FRONT TIRE-P265/40R17 YFU - REAR TIRE-P295/35R18
1SA - CORVETTE Z06 BASE EQUIPMENT GROUP 21U - ELECTRON BLUE METALLIC
70I - TORCH RED INTERIOR TRIM 704 - Z06 INTERIOR - TORCH RED
Hope this helps your out.
VEHICLE INFORMATION
430 N ALBANY AVE
(609) 344-2100
CLAIM HISTORY
VEHICLE BUILD
OPTION CODES
Listed selected options?
Sponge; the options listed appear to be just a selected list. I wonder how they compare to the options codes listed on the glove box door?
Also of noted is the gross vehcile weight at 3557 lbs.
99% of the time CF members come thru!!!!!!
Options list in the glove box are the same as what is listed above, AAB, MN6, U52 and so on. These are codes only and then a description of what the codes are.
Regarding Gross Vehicle Weight Rating : 1613 kg (3557 lb) That's exactly what it is GROSS meaning weight of vehicle with passengers, shouldn't exceed 3557. Hope this helps
Re Reading your question, the list of option for BillyT06 are not just a selected list, these are his list of options on his vehicle. It even tells you what color the car is. ELECTRON BLUE METALLIC with TORCH RED interior
Thanks Sponge, thats just what I needed. Now if I could pin down the sequence number I'd have everything I need. I think my car was within the first 15 Electron Blue Z06's made but I'd like to confirm that some way.
limited option list
Just wonder if others are aware this max weight rating. Obviously this GVWR has a direct correlation with the G/Y F1 tires but now wonder what tire pressure this rating is based ( commonly at the tires maximum tire pressure )? I deal with GVWR all the time but usually with our 40' motorcoach where weight and tire psi are continuely under surveillance.
My 2001 Z06 has 44 options listed on the build sheet and glove box. Just curious actually.
Thanks for posting.
Mike
VEHICLE INFORMATION
Merchandising Model : 1YY37 -2004 CORVETTE Z06 Warranty Start Date : 02/23/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : HENDRICK CHEVROLET
100 AUTO MALL DR
CARY , NC 27511-6031
(919) 380-8821
CLAIM HISTORY
09/16/2005 263288 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 4808 miles
09/09/2005 263288 # R3100 - INSTRUMENT CLUSTER HEAD UP DISPLAY REPLACEMENT 4809 miles
11/23/2004 238458 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 3023 miles
11/23/2004 238458 0 M0017 - LUBE, OIL AND FILTER 3023 miles
07/24/2004 227377 0 M0017 - LUBE, OIL AND FILTER 1816 miles
03/20/2004 216093 # C3157 - BODY LOCK PILLAR UPPER TRIM PANEL REPLACEMENT - RIGHT SIDE 699 miles
03/20/2004 216093 # J0990 - OIL PAN DRAIN PLUG REPLACEMENT 699 miles
07/22/2003 A01530 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1614 kg (3559 lb) Order Number : GJSH8Z
Build Date : 07/22/2003
OPTION CODES
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE4 - RIDE & HANDLING SUSPENSION SYSTEM
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
P12 - CAST ALUMINUM WHEEL R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS UN0 - AM/FM STEREO W/CD PLAYER
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
U73 - FIXED MAST ANTENNA VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME: FRONT
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XFW - FRONT TIRE-P265/40R17
YFU - REAR TIRE-P295/35R18 1SA - BASE EQUIPMENT GROUP
1SZ - PREFERRED EQUIPMENT SAVINGS 41U - BLACK
Received 1,041 Likes
2019 C6 of Year Finalist (performance mods)
production info
Spongevette, I have been trying to find this very information. Could you do me a favor and run my numbers ? Last eight numbers are 35110509. Thanks, I'll dance at your next wedding.
VEHICLE INFORMATION
Merchandising Model : 1YY37 -2003 CORVETTE Z06 Warranty Start Date : 12/11/2002
Delivering Dealer : NORTH STATE CHEVROLET COMPANY, INC.
451 N EUGENE ST
GREENSBORO , NC 27401-2115
(336) 379-8787
CLAIM HISTORY
01/27/2006 093595 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 6239 miles
10/14/2002 A10509 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1611 kg (3552 lb) Order Number : FQNZ33
Build Date : 10/14/2002
OPTION CODES
DD0 - ELECTROCHROMIC MIRRORS: INSIDE REARVIEW&LEFT OUTSIDE REARVIEW DD8 - OSRV
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
P12 - CAST ALUMINUM WHEEL SLM - STOCK ORDERS
1SA - CORVETTE Z06 BASE EQUIPMENT GROUP 1SZ - PREFERRED EQUIPMENT SAVINGS
70I - TORCH RED INTERIOR TRIM 70U - TORCH RED
build info
Sponge Vette, thank you for doing that for all of us. I don't know how much trouble it was for you but we all appreciate your help. Mike
Banned Scam/Spammer
Received 1,319 Likes
FYI
I got my history from Sponge Vettte via pm (Thank you very much )
I then started a thread in the technical section about the service 04006 that I had...
It turns out that GM put in the software "update" for the column lock so that your car will shut down if you get the message and go over 2mph.
Even if you have the bypass module, the code can still be thrown and your computer will leave you stranded somewhere even though the bypass module didn't allow the column to lock.
Further digging has led me to the good news that with hptuners you can change various settings to negate that factory "update".
I'll post a link to the thread once I get the hptuners screen shots and steps figured out.
