[Z06] Valve spring replacement - has anyone used the FelPro SS71039 Valve Stem Seals?
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
It says direct replacement for factory and both Summit and Amazon state it fits a 2002 Z06, but just curious if anyone has personally used them and if they are a direct replacement for factory seals.
They are less than half the cost of OEM seals and FelPro is a trusted brand, so trying to make the smart choice here.
Links:
https://www.summitracing.com/parts/fel-ss71039
Links:
Banned Scam/Spammer
Im about to do the same thing. I've already purchased the "blue" springs and was wondering about the Fel Pro seals as well. My Z only has 17k miles, but those rubber valve seals are now almost 16 years old, so replacement just seems smart.
Steve
Steve
Resurrecting this thread because I‘m wondering the same thing. Has anyone used these? I have a set on my bench and they are not like the factory pieces. I don‘t think these were intended for an LS7 despite all websites confirming fitment.
These felpros have an integral washer where the spring would sit on, but i feel the diameter is too small. Also, the washer construction would change spring pressure. Im afraid that these were $20 wasted, can anyone confirm?
thx, J
thx, J
Running Guns & Moonshine
I have used the LPE tool twice tongood success. There are similar clones out there now which cost less.
Banned Scam/Spammer
thx, J
thx, J
Just make sure they are correct, bought a car from a guy in here got it home and was changing the oil found a ton of material in the pan, ended up being all the valve seals were basically gone
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I put the fel-pro ones in my car last year when I did springs. I havent had any issues but I also have not dropped the pan to check. No smoking or anything. Mine sees over 7000rpm regularly though.
ArmchairArchitect (10-06-2022)
