[Z06] sway bar options
sway bar options
I am thinking of doing a sway bar upgrade to go with the coil over kit.
thinking 550/600 spring rate.
I see there are may options available...
afe/jerry o connel
lgm
gmpp
eibach
hotchkis
what I am thinking is either a gmpp kit or a gmpp front and a afe rear if they will sell separate.
if not then which would be more appealing?
afe set 35mm/29mm
gmpp set 38.4mm/27.5mm
what are your thoughts for the spring rates I have selected?
afe/jerry o connel
lgm
gmpp
eibach
hotchkis
afe set 35mm/29mm
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I went with the factory C6 Z51 bars F/R. DRM Z06 Bilsteins. OEM springs.
Turns in quick and neutral. Exits just a tad tight on the front.
Nice to have the NT05's for grip.
IMHO coil overs for the street are overrated.
dohcfiend (10-28-2017)
