C6 Jacking Pads
Old Feb 5, 2005 | 05:07 PM
jackcasa's Avatar
jackcasa
Default C6 Jacking Pads
Yeah, I know. We've done this before but I've "lost" the URL for the vendor and can't find on the CF or via goggle. I think it was Elite Engineering, maybe? Some help, please? :o
Old Feb 5, 2005 | 05:15 PM
natejohn's Avatar
natejohn
Originally Posted by jackcasa
".... I think it was Elite Engineering, maybe? Some help, please?.." :o
Yep - Elite Eng.
Though I went with the BMW pads and leave them in.....
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Here you go...
CLICK HERE
Old Feb 5, 2005 | 05:44 PM
jackcasa's Avatar
jackcasa
Thanks, Nomad. Now, does anyone remember the clearance from the pads installed to the ground surface? I want to remember 4.25", but I'm not sure of that.
Old Feb 5, 2005 | 06:07 PM
c606's Avatar
c606
Novice question, what are these use for?
Old Feb 5, 2005 | 06:14 PM
jackcasa's Avatar
jackcasa
Good question. There are four "slots" on the underside of the C6 ; two behind the front wheels and two in front of the rear wheels. These are to accept jacking pads which provide lift points for the car. The jacking pads are made of aluminum (or steel, depending on the manufacturer) and part of it is designed to slip into the slot and lock in with a quarter turn. At least I think that's correct. Lifting a C5 or C6 without using these pads is a potentially damaging proceedure, I'm told. That's why I want to order some from Elite Engineering.
Old Feb 5, 2005 | 07:16 PM
c606's Avatar
c606
Thanks for the explanation.
Old Feb 5, 2005 | 07:31 PM
ss409cid's Avatar
ss409cid
Me too
Old Feb 5, 2005 | 07:47 PM
Gray Weasel's Avatar
Gray Weasel
Default Jacking Pads
I thinkl you would be happier with the BMW pads you can put them in and leave them in they are made out of some kind of plastic and cost about 6 to 8 bucks each depending where you are located I have lost the part number I think someone will be able to help due a search on C-5 form the part number is the same for C-6
Old Feb 5, 2005 | 10:11 PM
natejohn's Avatar
natejohn
part # 51-71-1-960-752
Dealer (BMW of Mtn. View, Calif.) gets $9.60 ea. You can do better on the net.
I'll try to post some pictures tomorrow.
Old Feb 5, 2005 | 10:49 PM
Buster1's Avatar
Buster1
I got my EE jacking pads a few months ago. No probs with clearance. I don't know the exact numbers, but they are only about 1/2 inch lower than the rails when installed. They are a nice product too.
To C6 Jacking Pads
