Parking question
Old Feb 8, 2005 | 06:45 AM
sly1's Avatar
sly1
Default Parking question
I saw a C6 on the dealer's showroom, and there was a tag around the the manual shifter stating that the C6 muust be parked in reverse to prevent battery discharge. Naturally the salesman was clueless. What's the deal?
Old Feb 8, 2005 | 06:51 AM
Z064life's Avatar
Z064life
St. Jude Donor '06
In an M6, you must place it in reverse when you to fully shutdown the car
Old Feb 8, 2005 | 07:30 AM
bjmcphee's Avatar
bjmcphee
If the manual trans in not in reverse the accessory mode is on... thus draining the battery...
Old Feb 8, 2005 | 07:43 AM
Jinx's Avatar
Jinx
You might think it's annoying, but the car reminds you if you don't do it, and it quickly becomes habit.
Old Feb 8, 2005 | 10:12 AM
Violet's Avatar
Violet
..besides, it's just a good habit anyway.
Old Feb 8, 2005 | 10:19 AM
sly1's Avatar
sly1
I always leave my car in gear when I'm parked but it's always first and never reverse. It just so happens that it always seems that I'm parked on an incline and being in first gear is a good backup to my parking brake. So with a vette I guess i would have to back up into the parking space and then reverse would serve the same function.
TAG-D IT's Avatar
TAG-D IT
It was awkward at first... but it becomes a rhythm when you turn the car off and get out.
Old Feb 8, 2005 | 10:21 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
It's faster when you need to back out of a stall.
Old Feb 8, 2005 | 10:41 AM
Boozman's Avatar
Boozman
Old Feb 8, 2005 | 10:57 AM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default Listen
Right on. Set up you personal options for the car to holler at you if you don't.
Old Feb 8, 2005 | 11:03 AM
Tom/99's Avatar
Tom/99
I've been driving manual shift cars since the mid 60's. I was told then, to put it into reverse when parking.
Old Feb 8, 2005 | 11:58 AM
missprissybrat's Avatar
missprissybrat
From: If you believe you can tell me what to think... I believe I can tell you where to go ;)
I have almost always driven a manual shift car. (since the late 80's) I have never heard of this! I have started doing it, just to get in the practice, incase I ever do get my vert.
Old Feb 8, 2005 | 12:00 PM
TRAIL BOSS's Avatar
TRAIL BOSS
It does!
Old Feb 8, 2005 | 12:27 PM
TEAShea's Avatar
TEAShea
Reverse is actually better than 1st gear since it provides a higher ratio. As you all know it is the engine compression that keeps the car from moving when the car is parked in either ist or reverse.
TEAShea
from Nebraska
Old Feb 8, 2005 | 01:48 PM
sly1's Avatar
sly1
I was thinking that the only negative with having to shift the car into reverse is having to tell the valet driver to put the car in reverse when he parks it. I go to restraunts regularly with valet parking, but even if the guy forgets I suppose that two hours isn't going to drain the battery that much.
Old Feb 8, 2005 | 02:52 PM
antoniopaolo's Avatar
antoniopaolo
Missprissybrat this is where your youth may get in the way. I can recall my Dad teaching me this technique. But then there were many other techniques that I found it necessary to learn on my own.
If you keep practicing I bet you can get it right.
antoniopaolo
To Parking question
