Floor Jack
Old Feb 10, 2005 | 10:11 AM
FlaGuy's Avatar
FlaGuy
Default Floor Jack
Hi all, Find myself in need of a floor jack that fits under my C6. I'l be using the lift blocks. Any recommendations?
Old Feb 10, 2005 | 10:15 AM
DigitalMan's Avatar
DigitalMan
Sears has a nice Craftsman aluminum one for $99..
The Info
Old Feb 10, 2005 | 10:17 AM
vettnutt's Avatar
vettnutt
Few jacks will fit under the C6. The low profile racing jacks may. I have to drive onto 2 2x10's (2 under each wheel) first to be able to slide my jack under. If you're going to use jack stands, be sure to jack it up at the lifting points (see manual) and then slide the stands under your jack pads.
Old Feb 10, 2005 | 10:19 AM
hlcptr's Avatar
hlcptr
Can someone measure the clearance at the front and rear jacking points so I can see if my jack will fit?
Thanks.
C6FirstVette's Avatar
C6FirstVette
The Info
I have this jack and it works perfectly with the C6...I also have the Snap On sissor lift which even works better
Michael
Old Feb 10, 2005 | 10:24 AM
FlaGuy's Avatar
FlaGuy
Default Floor Jack
Thanks all for your input. I'm off to Sears.
Old Feb 10, 2005 | 11:05 AM
TEAShea's Avatar
TEAShea
I use Griot's heavy duty jacks. Excellent quality. They fit fine. They are, howeve, big, heavy and expensive. I have two and jack up both sides of the rear or front at once for better access to what I am working on.
TEAShea
from Nebraska
Old Feb 10, 2005 | 11:17 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Jacking Pads
Don't forget your Elite Engineering Jacking Pads. 4 for less than $40 and color coated.
Old Feb 10, 2005 | 11:18 PM
redhot6's Avatar
redhot6
Or you can buy the BMW 3 series jacking pads, either the round or rectangular ones will fit just fine. About $20 for all four.
Old Feb 10, 2005 | 11:32 PM
Smittybilt's Avatar
Smittybilt
I got a low profile jack from tooltopia.com. Works really well. I think it was about $180. Best price I could find for a low profile (I believe 3" minimum height) jack. Smitty
Old Feb 11, 2005 | 06:23 AM
mdcruiser's Avatar
mdcruiser
Just bought my jacking pads from Elite -- color coordinated!
Jeff at Elite sais that, for the money, you simply cannot beat the Sears Craftsman jack discussed above. It is on sale, $20 off, only through tomorrow (Feb. 12)! At least that is what the online listing says. I just bought one online for pickup at my local Sears store.
Old Feb 12, 2005 | 07:10 AM
AceVentura's Avatar
AceVentura
Curious.....
Could/Will the jack stands easily slip off the jack pads??
Thanks!
To Floor Jack
