Window Index....
Old Feb 11, 2005 | 03:50 PM
KLO's Avatar
KLO
Default Window Index....
Everyone has read how to reset the indexing when it gets off cycle, but does anyone know how to turn it completely off, I need to do this to make tinting the side windows easier....
Old Feb 11, 2005 | 04:13 PM
Asterism's Avatar
Asterism
the manual says you need to reinitialize after changing the battery,
so perhaps disconnecting the battery for a bit will do the trick.
Old Feb 11, 2005 | 04:18 PM
ant812's Avatar
ant812
i would think just disconnecting the battery and opening the hatch and releasing the doors would work.
Old Feb 11, 2005 | 04:22 PM
LKicklight's Avatar
LKicklight
Default Indexing
If you dis-connect the battery, only the drivers side window will not index, so put the pass.side down a little before you take the battery loose. After you're done, re-index the drivers window per the manual.
kickback
#5790
TRAIL BOSS's Avatar
TRAIL BOSS
My guess also. Let us know the answer!
Old Feb 11, 2005 | 04:24 PM
elmagoo's Avatar
elmagoo
You might want to take your top off as well if you disconnect the battery. Remember that the window has to lower to clear the top to be able to open properly. If you disconnect the battery, obviously this can not happen, hence you could damage your window .
To Window Index....
