Exhaust Mod Question
Old Feb 15, 2005 | 03:27 PM
RLIP's Avatar
RLIP
Default Exhaust Mod Question
While this is my 3rd vet I have bought, this is my first new one. My last one I bought used had a Corsa exhaust and I miss the throaty undertone that came with it.
So, I decided to do my first mod. I am going with a new exhaust. My question is this. How much can I do without threatening my factory warranty? I don't want to do anything that will void it, but I must be allowed to do some work, no?
Old Feb 15, 2005 | 03:58 PM
Boozman's Avatar
Boozman
Just had my Chev dealer install the Corsa Sports on my C6 man the are sweeeeeeeeeeeeeet alot more throaty that on my C5. I don't know about other mods because I like mine just the way it is.
Old Feb 15, 2005 | 04:00 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Just bought the corsa sports
Cant wait to put them on !
Old Feb 15, 2005 | 04:04 PM
hlcptr's Avatar
hlcptr
The Corsas are approved GM parts. No warranty issues.
Old Feb 15, 2005 | 05:42 PM
TYLERTONY's Avatar
TYLERTONY
What do these run for a C6? Thanks
Parts and install at GM...ball park
Old Feb 15, 2005 | 05:53 PM
FLC6's Avatar
FLC6
Only the Touring is an approved GM part. NOT the sport. Called GM myself.
Old Feb 15, 2005 | 05:56 PM
hlcptr's Avatar
hlcptr
Are you absolutely sure? I don't mean to question your comment, but the Touring and Sports share the very same mufflers and rear pipes. The Touring version only adds the H-pipe forward of the Sport components.
I would think that if only one version were to be outside of the GM approval, it would be the Touring version.
But, I have not spoken to GM.
Old Feb 15, 2005 | 06:01 PM
sdowney's Avatar
sdowney
that is not correct. the sport system is considered off road to gm. it is the loudest system corsa has. the diffrence is the sound level not whether or not you get the x pipe.
Old Feb 15, 2005 | 06:06 PM
hlcptr's Avatar
hlcptr
Interesting. OK.
Old Feb 16, 2005 | 09:45 AM
RLIP's Avatar
RLIP
So what I am reading here is that if I get the Corsas installed by a Chevy Dealer, my warranty should be fine. Is that correct?
Old Feb 16, 2005 | 11:35 AM
jazzlove's Avatar
jazzlove
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
I had Corsa Tours installed yesterday.... very sweeeet...
Old Feb 16, 2005 | 11:54 AM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default Corsa Sports
Actually, the difference between the Corsa Sports and Touring is that only the Corsa Touring system falls below the 95dB level and therefore is 50-state legal which is why GM stands behind the Touring system.
According to Corsa, the Sports system comes in at 98dB and is not permitted in three states as it exceeds their noise standards.
That said, I just had a B&B X-pipe and Corsa Sports (4 tips) installed on my ride this morning. God, it brings back memories of my '69 350-350 vert with side pipes when doing a hard run. At cruise (80+) in 6th gear the sound is no more intrusive than the stock system but the seat of the pants feel is now coupled with a more throaty sound.
I don't know if it has improved my RWHP/RWTQ but my pleasure level has peaked!!!http://forums.corvetteforum.com/newr...&p=1549797432#
Thumbs Up
Old Feb 16, 2005 | 11:56 AM
ALMS21's Avatar
ALMS21
Do Borla Stingers void the warranty?
Old Feb 16, 2005 | 12:01 PM
webdzynes's Avatar
webdzynes
Has anyone combined the Corsa sports with long tube headers? I'm wondering if there is a simple "swap" available - where no cutting or welding is necessary. The gains seem nice, around 25 rwhp, and should have no affect on most warranty issues (or so I'm told)...
Old Feb 16, 2005 | 12:03 PM
Oilpatch's Avatar
Oilpatch
What tipped you to the Tours rather than the Sport?
Old Feb 16, 2005 | 12:10 PM
webdzynes's Avatar
webdzynes
While its not the same, I checked both out for my C5. The sports sounded a tad louder but more importantly, were more "exotic" sounding. Not a deep grumble but rather a euro sound. I understand its the same for the C6.
Old Feb 16, 2005 | 12:30 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Warrantee
Cat backs will not affect the warrantee.
To Exhaust Mod Question
Old Feb 16, 2005 | 12:46 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
It will only affect the warranty if the warranty work is DIRECTLY related to the modded part.
For example, if you change the radio and then blow out the factory speakers, they could claim that was a result or your changeing out the factory radio. Fair enough.
However if you change the radio and have radiator problems, the two are not related and would be covered under warranty.
Old Feb 16, 2005 | 03:08 PM
jazzlove's Avatar
jazzlove
Easy. I didn't want my C6 to sound like a 60s' muscle car. I wanted just a little purr and growl, just enough to say "power", and it worked perfect!
Old Feb 16, 2005 | 04:48 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
No, just your ears...
