Nebraska Front Plate Solution
Old Feb 17, 2005 | 07:03 PM
TEAShea's Avatar
TEAShea
Default Nebraska Front Plate Solution
Here is my solution to the dreaded front plate delima. We shall see if it passes muster with the local constabulary.
TEAShea
from Nebraska
Old Feb 17, 2005 | 07:07 PM
bangbgC6's Avatar
bangbgC6
I find outward visibility is already limited in the C6, doesn't that block a good portion of your view?
I'm going with the No Plate solution even though it's illegal.
Do they still have annual safety inspections and stickers required in Nebraska?
Old Feb 17, 2005 | 07:10 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Wont that mess with your hud !
Old Feb 17, 2005 | 07:15 PM
VANISH's Avatar
VANISH
Just keep the plate with you in the car at all times. I wouldn't drive around with your front plate inside your windshield like that looks
Old Feb 17, 2005 | 07:19 PM
TEAShea's Avatar
TEAShea
Fortunately the location of the plate does not block any visability. Put a piece of cardboard there in your car and you will see. Were it an inch higher, it would block the sight over the fender.
TEAShea
from Nebraska
Old Feb 17, 2005 | 07:57 PM
TEAShea's Avatar
TEAShea
Nebraska doen not have annual inspections or safety stickers. I know that this solution is not as good as no plate at all but I think it might discourage some stops. I will only drive the car to car shows for the first year.
TEAShea
Old Feb 17, 2005 | 08:01 PM
C7 BOB's Avatar
C7 BOB
Besides looking ugly, it's not legal. The front license plate has to be "permanently attached" to the front of the car. Many have tried, but it doesn't work.
Old Feb 17, 2005 | 08:05 PM
C7 BOB's Avatar
C7 BOB
In fact, you are more likely to get stopped by a cop, who will tell you that it is not legal to do that.
Old Feb 17, 2005 | 08:11 PM
CROSSRAMZ's Avatar
CROSSRAMZ
Not to mention.......always the possibility you could be wearing that plate imprint in a bad situation..
Old Feb 17, 2005 | 08:14 PM
C64BC's Avatar
C64BC
Old Feb 17, 2005 | 09:33 PM
SA HEAT's Avatar
SA HEAT
Yep.....It will definitely get more attention from the HEAT being improperly mounted in the windshield than not having one at all!!! My advice.... leave it off! To tell you the truth, stops made for "no front plate" in states requiring them are made for a number of reasons, the most popular being for a probable cause stop because the officer wants to check someone out for whatever reason. (Before anyone attempts to flame me, many forms of criminal behavior are found and solved this way). If you get a ticket for no front plate, at least here in Texas, you either got yanked by a rookie, he or she is a ***** and/or was having a bad day, or you escalated the stop and pissed off the officer. Any average law enforcement officer will admit that writing someone up for no front plate is chickensh*t and anyway, in my opinion, most cops accept the fact that almost no Corvettes have them mounted. It just doesn't look right, legal or not.
Old Feb 18, 2005 | 09:47 AM
Tenderfoot's Avatar
Tenderfoot
You will probably attract more attention this way. More importantly, god forbid you get into a serious accident and if the plate is not mounted securely in its present location, it will go flying through your interior slicing up anything in it's path. Not a pretty picture.
Old Feb 18, 2005 | 10:22 AM
Periokid's Avatar
Periokid
St. Jude Donor '06
could be a nice projectile in an accident.
Old Feb 18, 2005 | 10:29 AM
Vette_DD's Avatar
Vette_DD
Yes, I think you should rethink your decision about the plate.
Old Feb 18, 2005 | 10:31 AM
Adam Boca's Avatar
Adam Boca
From: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
:iagee: with all other comments..
Adam Boca
from Kentucky
Old Feb 18, 2005 | 10:45 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Curious
What’s the KV0KV. Null Zero
Old Feb 18, 2005 | 10:47 AM
TEAShea's Avatar
TEAShea
KV0KV (null zero) is my ham radio call sign.
TEAShea
from Nebraska
To Nebraska Front Plate Solution
Old Feb 18, 2005 | 12:26 PM
7 OUT's Avatar
7 OUT
If you got in an accident, it probably wouldn't be a good idea to have that thing flying around in the cabin with you. It could chop some things off that you might not want to part with.
Dana
Old Feb 18, 2005 | 12:56 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
What's the fine for no front plate in Nebraska?
In my state, it's $101...that's why Red Racer wears a front plate nowadays. Had the fine been in the $25 - $40 range, I may have ignored that law. But over $100 makes me want to comply and save those $$ for some cool mods.
P.S. That plate location could cause some serious damage to your forehead in case of accident. You should probably move it.
Old Feb 18, 2005 | 03:25 PM
stanleyp's Avatar
stanleyp
TEAShea
from Nebraska
So where you gonna mount the antenna in that thing ?
