C6 Engine Cooling System Question
Old Feb 22, 2005 | 05:12 PM
SA HEAT's Avatar
SA HEAT
Default C6 Engine Cooling System Question
I assume that the C6 engine's cooling system has a 195 degree thermostat. I'm pretty sure a change to a 180 degree thermostat would require a computer reprogram, but does anyone know for sure or has anyone made a change? Because of Texas' heat and lack of winter I've changed thermostats to cooler ones in older vehicles but never one with more modern engine monitoring systems. Thanks.
Old Feb 22, 2005 | 05:44 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
yes i beleive it requires some programming
you may want to search under the tech section
Old Feb 22, 2005 | 07:52 PM
7 OUT's Avatar
7 OUT
Mine stays at 190.
Dana
Old Feb 22, 2005 | 08:01 PM
BHP's Avatar
BHP
Yes, 195*. Same stat and water pump is used on the 2004 C5s. You can get a 160 but I have not seen a 180 yet. You can cut out two coils (spring) and the stat will be fully closed at 180. Operating range 185+ and you must set fan lower.
Old Feb 23, 2005 | 09:05 AM
SA HEAT's Avatar
SA HEAT
To C6 Engine Cooling System Question
