Cleartastic?
I found it impossible to get all of the bubbles out since the directions say to spray water directly on the car and then apply the sheets over top. Uh, wouldn't this put water and bubbles behind the plastic?
Also, every little stray piece of dust that came along made a noticable bubble in the plastic.
In the end, the Cleartastic was anything but clear against the blue paint. The front two pieces say that they are supposed to "overlap" which creates a VERY noticable white line where the seam is. I'm beginning to think mud guards would look better!
It also seems like the pieces cover WAY more area than they need to. Something simple to cover just behind the front wheel and one each ahead and behind the rear wheel would seem sufficient. Instead we get six pieces per side!
Am I alone in having trouble getting this to work right, or am I just expecting too much from this product?
Any alternatives that anyone has experienced?
I currently have ZERO nicks or dings in the paint and would like to put some kind of protection there so that I don't end up with any.
Thanks!
Stephen
http://forums.corvetteforum.com/show...&highlight=bra
Here are a couple of ocis from that thread:
The entire nose of the car is covered, to about the line of the headlight tops (the headlights are covered as well).
Applied in a enclosed garage last night, approximately 55 degrees.
Just sent the whole mess back to Mid-America. Just a poor design in my opinion. Overlapping seams?!? How could that ever look flat? The rear looked like each piece had 1/2" gaps between the individual pieces behind the wheel. Great, unless the rock you kick up hits the paint there.
Just put three more coats of wax on the areas directly ahead and behind each wheel. Hopefully if I can keep the area slick it'll be more resistant to scratches.
I like the clear bra idea, but what I'm trying to avoid is the (possible) problem the C6 has with kicking up rocks from the tires and chipping the fenders around the wheel well.
Stephen
on the right front lower. Wish I'd done this earlier.
There are great threads refered in EHS' post as well. Best I've seen to date. Thanks EHS
The squeegee is the trick to get the air and water out...
