The dark grey calipers that come with the Z51 performance package. Will they fit non-Z51 C6 brakes? If so can I order them though Chevy dealers? How much will they cost?
The calipers on the Z51 are the same as on the base and F55.
Hummm....I'd check the part numbers first....
the Z51 has larger rotors than the base or F55 Vettes....
Per the GM web page refering to the Z51 " It features larger and thicker brake rotors that are cross drilled".
Seems unlikely the calipers would be the same.
Calipers are the same-just different brackets to accomodate the larger rotors.
