Drive by wire?
Now drive by wire steering scares me :-) specially if they decide they gona use Microsoft OS to control it... I can see it now:
"We are sorry, your car has performed an illegal operation. You will now be slammed into the center divider. Please stick your head between your legs and kiss your *** goodbye"
The first time I experienced "drive by wire" was in my wife's new Toyota. After driving this Toyota for a about a week, I came to realize that I had a very "disconnected" feeling with the throttle. It felt like the throttle would act a bit differently compared to what I was doing with my foot. I thought maybe there was some variable cam lever idea with the pedal or throttle linkage. So I set out to find it and modify it... and low and behold, upon doing some exploring, I could not find a throttle cable!
I then discovered that the system was all electronically controlled. I did further research and found that Toyota actually dials in a throttle response curve which is DIFFERENT than what you input with your foot. They dial in a bit of a "dip" upon first movement of the pedal, perhaps to reduce accidentally abrupt starts.... fuel mileage and emissions issues too probably.
Once I learned of this, I was quite upset... soon the computer will be DRIVING the car too!
Technology can indeed be cool, but also seems to be getting out of hand!. I want a car that I can control... me, the driver... not the computer. I don't need a computer to drive for me.So... once again, assuming that the C6 does have drive by wire, I really want to hear some opinions here. This is an important issue. Does Chevy build in throttle response curves that are different than the driver's input? Does the C6 seem to have a "disconnected" throttle feel?
Funny... when I first discovered the "drive by wire" set up in the new Toyota, my first thought was, "I can't wait to get a new Vette, because surely a true driver's car like a Vette would never have anything like that in it." Oh boy... quite surprised here.
I've always loved the old musclecars of the `60's and `70's... but got tired of dealing with their antiquated and often unreliable characteristics... but at least you could DRIVE them!
Do I have to actually go back to drum brakes, points, carburetors and 12 mpg to "improve" my driving experience?!?!?!
My opinion of the drive by wire in the Toyota is that it's fine for the average shmoe, but certainly noticeable and a bit irritating to someone who is a sensitive driving enthusiast. Gee, I felt it before I even knew it was there, before I had even heard of the system at all. I kept scratching my head thinking, "why the heck does this throttle feel and act funny".
Well, in that Toyota now, I just turn up the radio and try to drive it like my wife does, which means generally oblivious to all mechanical automotive functionality.... just blast the tunes, hit the gas, hit the brakes, get to point B from point A, and forget about everything else. Kinda sad really.
http://www.caranddriver.com/article....rticle_id=8011
"...And the "active steering" is, well, active at distracting—too much gain at low speeds, too little at high speeds. If you hustle the 545i into a decreasing-radius turn, you'll get to sample both extremes in the span of a second or two. Truth is, BMW needs to fear the sort of electronic gee-whizzery that currently pollutes so many Mercedes models."
Here's some technical detail on how it works:
http://www.autofieldguide.com/columns/1103pb.html
I believe hot rodding is truly dead as we know (or knew) it.
Malibu does NOT have steer-by-wire.
You are getting steer-by-wire confused with the EPS system, which is just an electric motor that is used for power assist, versus a hydraulic system with a pump.
Saturn was the first GM cars to have the electric power assist system installed. Basically, you have an electric motor on the steering column that provides power when turning the wheel.
Real life steer-by-wire uses actuators to actually turn the wheels, based upon inputs from a steering wheel sensor and other factors, instead of a rack and pinion gear as used in most US cars.
Going back to the original question, yes, I do notice a difference with driving my Vette or any other car with the so-called "drive by wire." It is not so much the feel of the throttle, I believe the General over the past five years has been able to get the feel back with the right pedal and spring action. What I find that I do not like is the lag time for the throttle to respond. I'm used to it, but would prefer it wasn't there.
I believe hot rodding is truly dead as we know (or knew) it.can see this already in the guys doing LS2edit and
the tuners who are jumping up and down waiting for
the beta.
It's remarkable actually.
I think the future is actually much more interesting.
Imagine this scenario (which might be only in a couple
years):
- you hook your laptop up to some connector under
the dash
- you do a 1/4 mile run
- you run some sw which analyzes the results of the
data gathered during the run
- it saves the old settings and flashes new ones
- you do your next run and the sw has corrected for
altitude, gas quality, humidity, etc and your next
run is 2/10 and 2 mph better.
Pat
Some of the GM trucks have the same set-up
