Navigation Commands
I remember their was a thread that discussed the commands. However, I searched and could not find it. If anyone remembers, please post a link.
Need some help!!!!!!
THANKS!
Good luck, Bob
POWER ON, POWER OFF, AUDIO ON, AUDIO OFF,
CD, AM ,FM1, FM2, TRACK UP, TRACK DOWN
SCREEN OFF,
AUTO MODE ON, DAY MODE ON, NIGHT MODE ON,
ZOOM IN, ZOOM IN MAXIMUM,
ZOOM OUT, ZOOM OUT MAXIMUM
DUAL MAP MODE, SINGLE MAP MODE,
NORTH UP, HEADING UP, CHANGE MAP DIRECTION
3D MAP MODE, 2D MAP MODE
LOUDER, SOFTER,
VOICE GUIDANCE ON, VOICE GUIDANCE OFF
HOME
ENTIRE ROUTE, ROUTE OVERVIEW
REROUTE, DETOUR,
DESTINATION MAP, QUICK, NORMAL, SHORT
POI OFF
GAS, PARKING GARAGE, PARKING LOT
CINEMA, MARINA, ATM , BANK, HOSPITAL,
AMERICAN RESTAURANT, I’M HUNGRY,
SHOPPING, SHOPPING MALL, MUSEUM
ONSTAR:
DIAL, 1ST DIGIT (reply), 2nd DIGIT (reply), … DIAL
CALL … NAMETAG
STORE, 1ST DIGIT (reply), 2nd DIGIT (reply), STORE,
NEW NAMETAG, repeat NAMETAG, repeat NAMETAG
MY NUMBER
UNIT, ADD
UNIT, VERIFY
Ooops, jumping off topic a bit.
Going down the interstate and the thing want me to get a burger or some damm thing! Very poor unit considering what is available.
To turn the POI icons off, simply press the talk button and say "P. O. I. Off."
To change your region, you'll need to go into the navigation setup. I don't have my manual with me or the Corvette, but if you click the onscreen menu button, there should be a "configuration" button. In that menu should be a region field and you can select the region you're in. If you can't figure this out, when I get home I'll play with the nav and post step-by-step directions.
I had that problem as well when I first got my Corvette and it took me a while to figure it out -- you'll also notice that it doesn't recognise any nearby towns either.
1. Press the "voice" button at the top of the navigation system -- it's the top most button on the left side -- and very clearly say, "P. O. I. Off." You should hear the navigation system reply with "POI off."
That should turn off all those bothersome icons cluttering the screen.
2. Getting your system to the correct region is a little more complicated -- but this is why you can't enter any local street addresses or destinations.
Press the Nav button to get to the nav system, and press the "I agree" button at the bottom of the legal disclaimer. Now, press the menu button displayed at the bottom left of the navigation screen.
Now, this is completely non-intuitive, you'd expect this setting to be under Navigation Setup, but you'll need to pick "Enter Destination". On this screen, you'll see a bunch of different soft buttons, but the one you need is in the upper left corner and says "Region".
When you select Region, you'll be presented with a map of the United States that's divided into 10 regions, and 10 buttons on the left side listing the different selectable regions. Again, non-intuitively, the map isn't touch sensitive. You'll have to select your region from the left-hand button choices. I don't know what region you're in, so I can't tell you which one exactly to press, but it should be obvious. Once you select the region, it should highlight on the map. Once it's highlighted, you can press the back button in the upper right corner and input a destination or back out completely to the map screen.
You'll only need to do this once, so long as you stay inside your region. If you need a destination in another region, then you'll have to go back to this screen and select it -- and you'll also have to change it back when you return home.
All of this is covered on page 5-6 in your navigation owner's manual. A run down of button presses follows:
Navigation hard button
"I agree" soft button
Menu soft button
Enter Destination soft button
Region soft button
Search area region button
Back button
Let me know if this helped.
We
