Those little lead weights they tap on the rim of the wheel or is there something else? What's stick on? An do all shops do stick ons? I would Hate to put on little lead weights on chrome rims espcially if the show!
Stick-ons are square lead weights about 1 cm^2
which are stuck to the wheel in an unobtrusive spot.
If you look at the stock rims which come on your C6,
you'll see them.
All the C-6 wheels I have seen from the factory have those stick on weights in very clear view inside the front edge. I saw one that had 14 weights on the left front wheel and it looked like "dukey"! For one of you gearheads, why don't you event a new way to balance these high performance wheel/tire setups that doesn't show. There is a challenge for someone, you might make some money too!
