MP3 Error - "TOC ERROR" then Ejects?
Old Mar 20, 2005 | 08:05 PM
mikejofgb's Avatar
mikejofgb
Default MP3 Error - "TOC ERROR" then Ejects?
I tried loading a CD into the 6-disc changer today. It was made up of MP3 files. As it loaded, about 20 seconds later (but before anything played) the display read "TOC ERROR" and the disc ejected. I can't find anything in the owner's manual about this - any idea what is causing this?
Old Mar 20, 2005 | 08:07 PM
JJayzX's Avatar
JJayzX
If radio is mp3 compatible it could be the player doesn't like the cd you used.
Old Mar 20, 2005 | 08:09 PM
Corvette400400's Avatar
Corvette400400
From: Horsepower is how fast you hit a wall, torque is how much of the wall you take with you Jacksonville, Florida
St. Jude Donor '05
Sounds like the Table of Contents on your disk wasn't burned or created correctly by your computer. The MP3 decoder in your CD changer can't read what is on the disk. Try checking your settings on your computer making sure that your burner is set to Close the Disk and not leave the session open. If your session is being left open then the disk is not playable yet. Other things can be the cause too, but that is the most common one i encountered before.
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
My guess is that TOC stands for table of contents. Is the media bad? I have a NAV, so I don't have the MP3 player and I'm just guessing. Do other media play OK??
Old Mar 20, 2005 | 08:11 PM
mikejofgb's Avatar
mikejofgb
Yes, I've burned a few other MP3's and they loaded and played fine. Just a problem with this one. I was concerned about the error message but if TOC stands for "Table of Contents" then I'm not too concerned. I'll just use the disc as a $0.05 frisbee!
Thanks for the quick feedback. You all are so helpful!
Old Mar 20, 2005 | 08:35 PM
Hoonose's Avatar
Hoonose
You sure it didn't say 'TOKE"
Old Mar 20, 2005 | 09:57 PM
mikejofgb's Avatar
mikejofgb
It definitely said "TOC ERROR"
Old Mar 20, 2005 | 11:38 PM
Hoonose's Avatar
Hoonose
Nerk nerk!:
toke ( P ) Pronunciation Key (tk) Slang
n.
A puff on a cigarette, marijuana cigarette, or pipe containing hashish or another mind-altering substance.
To MP3 Error - "TOC ERROR" then Ejects?
