Dash speaker
Old Mar 22, 2005 | 01:30 AM
dolphin2551's Avatar
dolphin2551
Default Dash speaker
Need directions how to replace dash speaker on the C6 to anyone who has done it and with what! Thank you in advance!
Old Mar 22, 2005 | 09:53 AM
Violet's Avatar
Violet
the grill covering it will pop off...with GENTLE prying. protect the dash surface... look *closely* around the grill perimeter and you'll be able to locate the points at which it's clipped. something like wide-ish flat blade screwdriver...or an interior trim tool...will do the trick.
once you have the grill off, the fasteners holding the speaker into the dash will be exposed. unscrew them. lift the speaker out till you expose the wiring which you can then unplug.
Old Mar 22, 2005 | 10:51 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
I picked up this Reinforced Nylon Pry Tool Set from eastwood and it maks all they trim removal tasks easy
http://www.eastwoodco.com/shopping/p...=1&keyword=pry
To Dash speaker
