Its easier, no tools needed, can do it all by hand. Just need to remove one tire at a time and you need two jacks. Loosen the lugs, jack the car up, remove the tire, you will see the black spring that goes from one lower A arm to the other side, it has a bolt with a rubber bushing on it, while the car is in the air, take the other floor jack and lift up on the spring from the bottom and get the jack as close to the A arm as you can, with the tension off the spring, you can turn the adjusting bolt with your hand all the way down on the bushings, thats it........
Why would you do this? Does this effect suspension travel?
Wow!! That sound awesome!!! I will give it a try tomorrow. Thanks a million.
Nice looking C5 in your avatar.... so what C6 did you get?
Thank you for the C5 comment.
I got a C6 coupe,
Auto,
1SB,
URB,
QG7,
G90,
U2K,
UE1
CC3,
Artic White w/Black interior.
This morning I will be having the windows tinted, lowered, an exhaust system installed and a set of OE chrome wheels put on.
Thanks for asking, Vinny
