Security
Old Mar 29, 2005 | 02:44 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Default Security
Anyone using some type of after market theft deterrent? I'm not sure how easily the C6 can be stolen, and hopefully no one has had their baby ripped off. On my C5, I use a metal cover that goes over the steering wheel. It has a space in the middle that will allow the Club to be attached. I use the quality Club with the cylindrical key. The metal cover is so they can't cut the steering wheel.
Old Mar 29, 2005 | 03:29 PM
Boozman's Avatar
Boozman
I use Smith and Wesson no problems so far.
Old Mar 29, 2005 | 04:13 PM
TommyV's Avatar
TommyV
Yeah, I use Glock, but I just don't want to come back to an empty parking space.
Old Mar 29, 2005 | 04:21 PM
LS WON's Avatar
LS WON
Default How about the Pedal Jack it goes between the brake and clutch?
Mossberg works good too.
Old Mar 29, 2005 | 04:29 PM
PJinNJ's Avatar
PJinNJ
Default Don't know
I don't know how easily one could be stolen, but if they figure it out "Revelco" is the only way to go. Then a tow or flatbed is all you have to worry about.
Old Mar 29, 2005 | 04:43 PM
LS WON's Avatar
LS WON
Default Alot of times I find these anti-theft devices can be an inconvience to the owner.
Alarms included as when something goes wrong it messes everything up.
Old Mar 29, 2005 | 05:04 PM
stlthxlr8r's Avatar
stlthxlr8r
I have a lock that goes around the clutch. It basically prevents the clutch from being depressed which prevents car from being started even with the FOB. I gues the only way around it is a flatbed.
Old Mar 29, 2005 | 05:19 PM
digbyamb's Avatar
digbyamb
Trunk Monkey - Theft Retrieval System
http://www.trunkmonkeyad.com/4wmv.htm
Old Mar 29, 2005 | 05:43 PM
Rob4092xx's Avatar
Rob4092xx
The Club is worthless!
All the bad guy needs is a pair of sharp scissors to cut through the steering wheel and rotate the Club off.
Old Mar 29, 2005 | 05:53 PM
TommyV's Avatar
TommyV
That's why I use the metal cover. The Ravelco looks interesting though.
Old Mar 29, 2005 | 06:02 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Man i love the trunk monkey
You beat me to it iwas trying to find it
Old Mar 29, 2005 | 06:21 PM
Knaggster's Avatar
Knaggster
I would have thought that it was pretty hard to drive away without a FOB. A determined thief and a flatbed can steal just about anything, and then, hopefully, there's OnStar.
Old Mar 29, 2005 | 06:45 PM
C6ULATER's Avatar
C6ULATER
I had a lo Jack system installed. Also helped reduce my insurance rate.
Old Mar 29, 2005 | 07:55 PM
sallen619's Avatar
sallen619
Default 15%
also got the early warning system
Old Mar 29, 2005 | 09:44 PM
DP Dave's Avatar
DP Dave
After looking at the Club, etc. I decided something different. I just purchased (waiting for it to arrive) an Alpha Wheel Lock. It uses the same principle as the "Boot" that law inforcement agencies use. It attaches to the wheel so the car can't be driven.
Old Mar 29, 2005 | 09:48 PM
dvarapala's Avatar
dvarapala
Making CFOT Great Again
And what do Smith and Wesson do when you're away from your car and someone steals it?
Old Mar 29, 2005 | 09:50 PM
dvarapala's Avatar
dvarapala
The problem with On*Star is that all the thieves know about it - and which antenna to remove in order to defeat it.
Old Mar 29, 2005 | 10:11 PM
Knaggster's Avatar
Knaggster
Approximately how much does LoJack cost? I couldn't get any indication from their website.
To Security
