New C6 tips???
Old Mar 30, 2005 | 10:47 PM
MN6Z51's Avatar
MN6Z51
Default New C6 tips???
I'm picking my C6 up on Friday any advice on things to look for? Is Black on Black.
Besides remembering when parking MN6 to put it in reverse any other advice on commonly overlooked things?
Old Mar 30, 2005 | 10:53 PM
Vette_DD's Avatar
Vette_DD
I'd look the paint job on the exterior over carefully for any kind of blemishes. Same for the inside. If possible, see if most of the extras work, radio, Nav if you have it, CD, seats, tilt steering wheel, mirror movement, hatch release, fuel filler door, hood release.
Old Mar 30, 2005 | 11:06 PM
RX4WRK's Avatar
RX4WRK
Be careful not to over-fill the gas tank...do not add any after the first time the pump shuts off.
Now, hold on for dear life...
and have Fun!!
Old Mar 30, 2005 | 11:42 PM
DP Dave's Avatar
DP Dave
When you shut off the car make sure you set the parking brake along with shifting into reverse!
Old Mar 31, 2005 | 12:43 AM
digbyamb's Avatar
digbyamb
I have set mine up to exit assist (where the seat travels back and the steering wheel retracts) when I exit the car. This is my indication that the transmission is in reverse and the parking break is on. If the seat and steering wheel do not move to the easy exit positions I know I have not set something correctly.
Old Mar 31, 2005 | 06:16 AM
TRAIL BOSS's Avatar
TRAIL BOSS
If possible take a friend along to look the car over for you as you will be so excited you will not "see or remember" a thing
Old Mar 31, 2005 | 06:23 AM
fastdriver1's Avatar
fastdriver1
Default Parking Brake?
I'll be picking mine up (hopefully) in a couple of weeks. I've seen a couple of you say that the parking brake has to be on. Is it necessary to use the parking brake at shutdown (MN6) ? For years I have almost never used the 'E Brake', just left it in gear.
Old Mar 31, 2005 | 06:30 AM
C6FirstVette's Avatar
C6FirstVette
Set the DIC for your personal message; READ the manual carefully...full of info beyond 'fasten you saftey belts'; set memory seat function; hide fobs except the one you need Order Lloyd front and rear mats; enjoy the hell out of the car
Michael
Old Mar 31, 2005 | 06:31 AM
C6FirstVette
Yes! Know it is strange to do (I like you never used the e brake) but it is a must for the C6 due to electronics
M
Old Mar 31, 2005 | 08:48 AM
OWENMUSTANG's Avatar
OWENMUSTANG
and check the paint both out in the sun and inside the shop.
black reveals all, just need to have the right light source.
Old Mar 31, 2005 | 09:08 AM
rushguy's Avatar
rushguy
Tell the dealer not to prep it maybe..they might give it some nice swirl marks for life.
Old Mar 31, 2005 | 09:26 AM
Corvette Girl's Avatar
Corvette Girl
"When parking MN6 to put it in reverse any other advice on commonly overlooked thing"
What is MN6? Why in reverse? Sorry for the stupid question, I pick up my C6 Sunday!
Old Mar 31, 2005 | 09:28 AM
Knaggster's Avatar
Knaggster
MN6 is the six-speed transmission, and if you don't put it in reverse to park, you'll drain the battery.
Old Mar 31, 2005 | 09:31 AM
AutoCutter's Avatar
AutoCutter
Believe or not this is , in my opinion, the single best tip for those who have any electrical snafo's. Carry a 10mm wench in your car-it will allow you to disconnect the negative ground from the battery to reset the system in the case of an extreme electrical snafo
Old Mar 31, 2005 | 09:40 AM
AutoCutter's Avatar
AutoCutter
MN6 is the 6 speed manual trannie. Parking into reverse allows the complete computer system(sans FOB sensor) to shut down. If you don't go into reverse(Park for Auto) the computer system only shuts down in part, leaving several systems operating at full power which will drain a battery to the point the computer system will not allow the car to attempt a start. This point appears to be 12.2 volts.
Congrats for the new VetVert, it is one hell of a ride!
Old Mar 31, 2005 | 11:02 AM
Low Rider's Avatar
Low Rider
NO just reverse....I also don't use the E-Brake much either but maybe that is why my exit mode doesn't seem to work I just set up the other memory button (2) for the exit mode I wanted and it works fine....no E Brake
Old Mar 31, 2005 | 01:28 PM
Boozman's Avatar
Boozman
Make sure both keys work to open the hatch.
To New C6 tips???
Old Mar 31, 2005 | 01:44 PM
mforman42's Avatar
mforman42
I'm confused. (I know that's not unusual.) Why not just use the e-brake so the car will work like it is designed? Seems like that's better than giving up a second seating position and automatic movement of the seat when you open the door. Anyway, it's your car, do as you wish.
Old Mar 31, 2005 | 01:51 PM
Funster's Avatar
Funster
Make sure you check to see that both seat heaters work...
Old Mar 31, 2005 | 02:43 PM
7 OUT's Avatar
7 OUT
No but it is a good idea to use it.
