warning labels
Old Apr 2, 2005 | 09:46 PM
aaflame33's Avatar
aaflame33
Default warning labels
I removed the warning labels on the visors with hair dryer but I can still
see where they were. Some kind of stuff left.
Any ideas on how to remove it?
Old Apr 2, 2005 | 09:47 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
goo-gone.
S2K's Avatar
S2K
Goo Gone did not work for me.
http://forums.corvetteforum.com/show....php?t=1053533
Old Apr 2, 2005 | 09:48 PM
aaflame33's Avatar
aaflame33
Originally Posted by lager99
goo-gone.
okay where do I get goo gone?
Old Apr 2, 2005 | 09:50 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
I'm keeping my C-6 original..................
Old Apr 2, 2005 | 09:52 PM
aaflame33's Avatar
aaflame33
Default goo gone
Thanks S2K I'll try both methods.
Old Apr 2, 2005 | 09:54 PM
aaflame33's Avatar
aaflame33
Hey Artic White I got the same color, ain't it beautiful.
Old Apr 3, 2005 | 04:39 AM
richbell's Avatar
richbell
I agree.. I don't have a problem with any warning sticker or labels inside my car Labels that indiicate "danger" and "warning" in yellow are OK with me and add to the excitment.
Funny.. when you own a classic you have points removed for not having the factory stickers present in your car.
Thinking about adding this one below (but only on the passenger side )
Old Apr 3, 2005 | 09:23 AM
drtli's Avatar
drtli
CRAZFST
One more time
Since it is a hot glue adhesive and not solvent based, heat is the way to go. Residue removes easily if you heat it with the drier and brush off. I used a brass bristled suede brush and drier set on high. Looks perfect
Old Apr 3, 2005 | 09:35 AM
NavyC5's Avatar
NavyC5
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
I used a little bit of lighter fluid to get any residue off.
To warning labels
