Navigation/Radio Question?
Old Apr 3, 2005 | 10:19 AM
Colby08's Avatar
Colby08
Default Navigation/Radio Question?
Am I missing something or is there no way to change to pre-set radio stations without exiting from the navigation screen?
Old Apr 3, 2005 | 10:31 AM
skfurr's Avatar
skfurr
Nope, you can seek up and down through the frequencies while on the nav view, but you must hit source before you can change which preset you're listening to. The presets are soft buttons only on that screen.
Not a big deal, hit source, change channels, then hit nav again (if you need to see the map realtime.) I find that I just use the HUD for the directions most of the time and leave the unit on the radio screen.
Stephen
Old Apr 3, 2005 | 10:54 AM
TYLERTONY's Avatar
TYLERTONY
While we're on the subject with XM radio, since they have 150 channels, is there any fast way to get from channel 150 to say channel 50 without holding the channel down button for so long? Any tricks???
Old Apr 3, 2005 | 10:58 AM
skfurr's Avatar
skfurr
Select a preset closer to 50, then channel up/down from there? Not much easier, granted.
Stephen
Old Apr 3, 2005 | 11:39 AM
crabman's Avatar
crabman
This is the biggest voice command that they missed. It would also be nice if they added a function to switch from dial to preset and then you could just hit the rocker and surf the presets that way.
Old Apr 3, 2005 | 11:56 AM
Colby08's Avatar
Colby08
I guess I am fickle but I am constantly changing radio stations and it's a PITA to keep going back to the nav screen.
Old Apr 3, 2005 | 03:30 PM
shopdog's Avatar
shopdog
Hold the up/down hard switch for 5 seconds and it will scan the presets instead of scanning the whole band. Or so says the manual. I've had trouble making it work.
Old Apr 3, 2005 | 04:39 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Don't know if it's different on the other radios. On the NAV radio it's not the up down seek hard button that does this. It's the scan button on the touch screen that you want to press and hold.
Old Apr 3, 2005 | 05:27 PM
crabman's Avatar
crabman
I didnt word it very well, what I would like to have is the ability to hit the rocker and have it go to the next preset, hit it again to move to the next, and so on. This could be toggled by a function softswitch on the touchscreen.
Old Apr 3, 2005 | 06:10 PM
mforman42's Avatar
mforman42
Yes, the XM band is broken up into sections (I'm not in my car, so I forget what they're called), and you can cycle through the sections until you're in the right one for your type of program. Basically, it starts with 'decades', then 'country', etc.
Old Apr 3, 2005 | 06:11 PM
shopdog's Avatar
shopdog
It won't do that, but I agree it would be nice if it did. On the topic of dialing up an XM channel, there ought to be a keypad screen so you could just directly enter the channel. It doesn't have it, but it should.
Old Apr 3, 2005 | 06:35 PM
crabman's Avatar
crabman
I know it wont, I have been carefully through the manual at this point. I also tried various voice commands that I thought might exist but were not documented but did not find any. Hopefully Chevy is listening. I carefully filled out the questionairs and mentioned these things so as to do my little part.
Old Apr 4, 2005 | 08:17 PM
skfurr's Avatar
skfurr
Default $afety Naz1s...
I wish we had such a capability. However, some corporate lawyer at GM decided the liability of our PASSENGER working something as complicated as a KEYPAD would be too distracting to the driver.
My wife's '05 STS has a keypad input on the touchscreen for the OnStar phone dialing and the Bluetooth phone dialing. Both "grey" out above about 2 MPH. WTF?!?! Why can't a passenger dial a phreakin' phone number, or choose a radio station by number? Why not use the passenger seat "weight sensor" that determines whether a passenger is sitting in the seat for airbag deployment reasons (and if that person is > 40lbs in weight; lower inflation speed for children?) If there's a passenger present, enable the "distracting" functions. Geesh.
I'm just gonna keep on bitc4ing until someone in GM gets a clue and realizes that:
1) We have a 3200 lbs missle,
2) With 400 HP at our command,
3) But they don't trust us to have the attention span operate the touchscreen,
4) Even after we read a whole page of disclaimers and press an "I AGREE" button.
This really pi$$e$ me off... BTW, the Bluetooth handsfree works perfectly if I pull my damn phone out of my pocket and dial the number on that. Why would keying it on the touchscreen be ANY less distracting than using a tiny handset??!?!!?!?!??!?!!!
Stephen
To Navigation/Radio Question?
