Is ARCO gas really bad for a C6????
#41
Making CFOT Great Again
Originally Posted by calemasters
Currently, Top Tier Detergent Gasoline Standards are meet by:
Chevron
QuikTrip (not to be confused with KwikTrip)
Conoco
Phippips 66
76
Shell
Entec
MFA Oil Company
Chevron
Conoco
Phippips 66
76
Shell
Entec
MFA Oil Company
#42
Originally Posted by rm50
I have owned 4 vettes over the last 10 years. I have never given any thought to where I buy my gas. It is always the most convienant place around. I have never had any bad gas or had any loss of performance because of the gas. Am I lucky or is all gas basically the same?
Now gas does vary *by region*. Volatility may be different, it may contain oxygenates for smog abatement, etc. But all gas in a given area will be the same formulation. Again, the only difference is the couple of Kool Aid sized packs of detergent added by the truck driver to each 10,000 gallon load.
#43
Originally Posted by mlongo99
Arco isn't a "top tier" gasolene. That means there really is a difference in the amount of added detergents. I'd avoid it unless you don't mind risking a broken fuel sending unit. And if you plan on keeping your vette for a while, wouldn't you feel better knowing that you used fuel that helps clean the motor?
#04-06-04-047D - (March 17, 2005)
http://corvettemechanic.com/board/in...T&f=20&t=2110&
many thanx to corvettemechanic.
#44
Originally Posted by Zig
one way to tell if the filters are getting full is how fast the gas dispenses. the slower the fuel rate the fuller the filters are.
Thanks!
#45
The one time I filled up my tank with a non-Top Tier, I got the FSU problem (crazy fuel gauge + Service Fuel System message)
I am going to stick with Top Tier's as published even given the fact GM designed the Fuel Sender cards with little or no tolerance to anything but top notch stuff.
#46
Elite Torch Red Member
Originally Posted by GGWOODY
Went out with a girl for a while that worked for an environmental company that monitored gas station safety and regulatory. She said that in SoCal, all gass comes from 3 refineries. The additives are the same; any difference is in your head...whether it be chevron, mobil, shell, arco, or thrifty..it's all the same and even if they don't advert the additives they are in there. This is the case in Southern Caifornia, I don't know about the rwest of the country. Since this chick spent 6 hrs a day auditing andmonitoring gas stations, I'll take her word for it...and she was HOT!!!
#47
Originally Posted by black783
If any one uses ARCO on a regular basis and has not had a problem let me know. The reason I'm interested is that this is the easiest station for me to go to.....
#48
Originally Posted by JWD01
I've put Arco in everything from my C5 to my lawnmower and have never had a problem. My truck has 80K miles with nothing but Arco gas with NO problems. Those who say it all comes from the same place are correct. Those who say one's better than the other, buy into all the marketing hype. As far as the secret additive being put in by the driver (a little packet into 5000 gallons),
#49
Just north of Boston, there is an "oil farm" (fuel tanks).
Watch the tractor trailer tankers fill up from the same pump and then deliver to all the different brand gas stations.
End of story.
End of story.
