Considering an Optima?
We just went through this with our 2005 C6, and as in our previous '01 C5 an Optima was the cure for the GM "battery blues". Here's what we used:
Optima Redtop
Part # 8004-003
Model # 34-78
CA - 1000
CCA - 800
Now then, once you exercise your due diligence and do your research you will find that the Optima is slightly larger in it's physical dimensions. Does this cause any "issues" you ask with the install?
Yes and no. There is one minor issue but it's so easily fixed that it's not really an "issue" at all. Let me detail the issues or lack thereof in swapping an Optima of the part number above for your stock C6 battery.
In width there were none, the battery fit fine in the stock tray and the stock hold down worked with the Optima.
In height, again, no issue. Fits fine in stock location.
The one fitment issue we encountered was with the positive battery terminal/cable. Because the Optima is slightly larger in the "length" dimension, it sits a little "closer" in to the passenger side inner fender and the postive terminal is in a slightly different place than the stock battery.
Consequently once the battery is completely in place and the hold down is clamped down, the positive terminal is below and obstructed by the hood bracket/support directly above it. I've included a picture below for reference. Anyway, once it's in place, you can't get a socket on the positive battery cable terminal to tighten it up. Ask me how we know. LOL
It's just a minor issue. The cure? Sit the Optima in place, but don't slide it fully into the tray. Put the positive cable on the terminal, tighten it fully and THEN slide the Optima into place in the hold down. Clamp it down. Replace the negative cable, tighten and you're done.
There you have it. I hope the picture above helps. Although it may not look like it interferes, it's the bracket noted that gets in the way. If I had shot the picture from directly above you'd be able to more easily see how it gets in the way but then it wouldn't have been much of a picture. LOL
Oh, and since we replaced the crappy stock battery with the Optima, our "battery blues" have been cured and everything has been milk and honey.
Vi.
I'll be mounting the stock cables to the side mounts via THESE TERMINAL ADAPTERS and I'll be using the top terminals for all of my aftermarket electronics connections via THESE
Good info Violet.
I still do.
Sorry you feel that way Ted. That's my car in the picture and my fiance' making the post.
I feel your pain though as I have the same sentiments towards the stock AC Delco batteries that Chevrolet installs in these cars in Bowling Green.Although, my experience with Optima's has been great. I had one in my 2001 C5 that I installed, surprise surprise, when the Delco battery died leaving me stranded for no apparent reason. Out with that crap, in with Optima, problem solved. 4 year and not one missed start.
So, fast forward to new 2005 C6 with 300 miles and >boom<. No start. No click. No door/hatch unlock. No nothing. Out with one crappy Delco battery and in with new Optima Red Top. 400 miles since then and no problem. We'll see how the rest of the story unfolds.
Regards,
BadAttitude
Oh, and I almost forgot. Looky what we have here! CF.com's number one off-topic juvenile delinquent over here in C6 General actually trying to "help". How cute.
Sorry, could not resist. I'm a bad person.
Regards,
BadAttitude
Good luck with whatever you're using now, sounds like a streak of good luck certainly wouldn't kill you. LOL
BadAttitude
Now then, TedG's abberation aside, everyone else that loves their Optima, pay attention to Miss Thing's install instructions. Maybe we'll keep her out of off-topic. LOL
