GPS problems
Old Apr 7, 2005 | 10:56 PM
mrpms's Avatar
mrpms
8th Gear
Default GPS problems
My GPS gives me the wrong direction, or I should say, very inefficient directions. For example, driving from Toledo, Ohio to columbus, Ohio it either has you drive 35 miles out of the way or using different settings, go through every small town between the two, taking an extra hour. I called GM and they said that is how it is supposed to work. I also have a portable GPS from Magellan and it gives very accurate and much easier to follow directions. The Magellan works so much easier and is much more user friendly.
The Corvette's GPS always knows were it is, but many times gives crazy directions to were you want to go. For an $1800.00 option I think it should work as least as well as a cheaper (less than $800.00) portable GPS.
Does anyone have a fix for this problem?
Old Apr 7, 2005 | 11:37 PM
Braced's Avatar
Braced
A $3 map! I feel your pain. Mine does the same thing. I was driving between Phoenix and Las Vegas and the thing wanted me to turn left in the middle of the desert! Then I'd pass the "turn" and it would say to continue on this road. It did that 6 or 7 times. I think it is a great tool most of the time. But nothing beats a hands on road map!
I think this mobile GPS nav system technology is still in its infancy. I'm willing to bet that in 5 years time it will be leaps and bounds ahead of what it is today.
SB
Old Apr 7, 2005 | 11:58 PM
sedonacorvette's Avatar
sedonacorvette
Default answer gps
How do you have it programed? There 4 options. Fastest Shortest Non toll etc.
Old Apr 8, 2005 | 12:05 AM
Lowlead's Avatar
Lowlead
Originally Posted by mrpms
My GPS gives me the wrong direction, or I should say, very inefficient directions. For example, driving from Toledo, Ohio to columbus, Ohio it either has you drive 35 miles out of the way or using different settings, go through every small town between the two, taking an extra hour.....
Just a thought... Did you make sure the the "Allow Major Roads" feature was selected in the Route Preferences menu? Mine calculates some pretty strange routes sometimes but not as bad as you've just mentioned.
Also a possible work-around: If after you enter a two point route (like the one you listed above) try ADDing a waypoint or two on the desired highway(s) using the map panning feature, the NAV unit will usually calculate a much more reasonable route. An example would be add a waypoint on HWY75 near BowlingGreen and another at say HWY31 near Kenton. This may not be the route you had in mind but you get the idea.
Old Apr 8, 2005 | 12:50 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
SB
Sorry to debate you, but my 5 year old Alpine NAV and 2 year old Garmin 2610 has always been accurate, it may not always find the best route, but has NEVER failed to get me to my destination...
However on the 5 year deal, of course I agree, but thats the way it is with almost everything electronic that is not made by GM
Old Apr 8, 2005 | 12:58 AM
Mocoso's Avatar
Mocoso
I suspect either your dealer or yourself while playing with it accidentally configured it to not use major roads, skip highways,etc... as others stated here check yer settings - Ive seen it give odd routes for one or two of the three basic route options - just have to check which ones it offers and pick the correct one
Old Apr 8, 2005 | 08:04 AM
mrpms's Avatar
mrpms
8th Gear
yes I've tried all the settings, allow major roads, toll roads, etc. I took it to the dealership and the service manager couldn't make it work either. It works so bad, when you put the dealership in as the destination, from about a half mile away,it makes you drive about a mile out of the way to get there. G.M. said that is the way it's suppossed to work. They are making me very upset. If they can't make it work, they should at least refund the price of the GPS.
I have owned a 1985, 1987, 1995, 1997, 1999, and now a 2005 corvette. If they don't make this right, I'll never buy another G.M. product.
Old Apr 8, 2005 | 08:12 AM
Knaggster's Avatar
Knaggster
Mine has been pretty good, although occasionally it has had me take a route that seems less efficient. I don't know whether that's a function of the system or the age of the map disk.
As far as your problem is concerned, it may be worth trying to find another C6-with-nav owner that can calculate the same route as you. That would distinguish between problems with your particular nav and the GM system in general.
Old Apr 8, 2005 | 08:27 AM
VITIS's Avatar
VITIS
Active Streak: 90 Days
St. Jude Donor '15-'16,'18,'19-'20
Good idea for trouble shooting your problem. That's not the way the NAV should work. The only time I've had your problem, the "allow major roads" was not back lit (note: if you touch it to darken, it is "off"). If all is as you say, then you may have a software glitch with this particular screen. Another thing, always go to the "3 route" option and look at the routes to choose the one you actually want. The NAV is like a computer, you have to figure out how to correctly tell it what you want it to do. Once you do, it's a great feature.
Old Apr 8, 2005 | 08:48 AM
mrpms's Avatar
mrpms
8th Gear
The Dealer took a Hummer out with the same system and it gives the same wrong directions. I think it is just bad programing in the system. I don't think it is fixable without getting new softwear for the GPS. Therefore, I think they should refund the price of the option, because the way it works now, you have to stop and get directions becasue you can't trust any directions it gives you.
Old Apr 8, 2005 | 08:59 AM
mrpms's Avatar
mrpms
8th Gear
I know that if you drive the way you are supposed to go, I75 to rt. 15, to rt. 23, that ithe GPS will eventually start giving better directions, but that means that you have to know the correct way to get to a destination before using the GPS. I bought it so it would give me, not me force it, to get somewhere.
Knaggster's Avatar
Knaggster
Well, good luck with that one . . .
I must say that my experience has been much better, and with the exception of an occasional glitch, it has been pretty accurate. Perhaps it's just some inaccuracies in your local map.
Old Apr 8, 2005 | 09:01 AM
mrpms's Avatar
mrpms
8th Gear
I've tried every combination, it gives different wrong directions
Old Apr 8, 2005 | 09:06 AM
mrpms's Avatar
mrpms
8th Gear
We have tried every combination and when you are given the three options, they all will get you there, but the routes are all crazy. They either take you 30-40 miles out of the way or though every small town taking at least an hour longer than needed. None of the options will take you on the "normal" route. If you stop and ask directions from anyone, no one will give you the ones the GPS shows because no one in their right mind would choose those routes.
Old Apr 8, 2005 | 09:23 AM
PJinNJ's Avatar
PJinNJ
Default Hmmm
Hey, I think this may be simple to fix, I had the very same issue and after days of working with it found it was so simple I laughed. There is an orientation screen where your car is shown as an arrow and you need to go to a fixed major road or other known place and use that screen to rotate the arrow to show the direction of your car at that point. Mine was about ninety degrees off and thus the unit was taking me all crazy routes because I wasn't going where it thought I was. When I reoriented the position and direction all is now well and while the unit isn't as easy to use as my Garmin2610 the routes and direction are just as effective. Good luck.
Old Apr 8, 2005 | 11:03 AM
mrpms's Avatar
mrpms
8th Gear
SB
If the GPS cost $3.00 I wouldn't complain, but I also have a Magellan GPS so I know I don't have to wait 5 years to get one to work, the Magellan works now.
Old Apr 8, 2005 | 11:11 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Mine always gives me 3 options before I start, I can calculate & look at either.
Old Apr 10, 2005 | 10:29 PM
dvarapala's Avatar
dvarapala
Making CFOT Great Again
I don't think it's his settings.
I just tried it myself, and it routed me along some cockamamie route down back country roads through a little town called Alger.
Looks to me like some kind of map database problem...
To GPS problems
