Spare Key (FOB)
Spare Key (FOB)
I just ran a search and did not find an answer so here goes a silly question.
How do you carry a "spare key" to a C6, or are you just out of luck if your keys are lost / stolen and you don't have another FOB in your pocket?
Is there a way to get into the car without the FOB?
Is there a way to start the car without the FOB?
Thanks,
Bud Gordon
Thanks,
Bud Gordon
Thanks,
Bud Gordon
Thanks,
Bud Gordon
You can get into the car with the key by using the key to open the rear hatch and then pull the release cable to open the drivers door. You can not start the car without the FOB.
Originally Posted by Hoonose
They give you an emergency key with each fob, that works as described above.
What would your gizmo do?
onstar
I think hiding a key is my solution. It doesn't start with a key so I'm not to worried about it. If someone is going to break into it, there going to do it anyway. I just dont like carrying this key around that I hope I never have to use.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Someone talked about stashing an extra fob without the battery in the car. If you stick the dead fob in the slot in the glove compartment you can start the car.
Stash the key outside, carry it with you or call ON Star.
Start the car without a FOB, so when you got her unlocked, you can drive home. Maybe a microswitch somewhere? You wouldn't think it would be hard to engineer.
