I am trying to hard wire my V1 detector so that it will turn on and off with the ignition. Tried using the wiring for the mirror, but the 2 hot leads stay hot all the time ( not switched as with the 1SB), and I have more than once forgotten to turn off the V1, and come back several hours later and its hot as hell.
I can't seem to find a switched wire under the dash or at both fuse boxes, without tearing up a harness, which I am loathe to do.
Any 1SA's out there that has already solved this problem ?
go to the fuse box under the passenger side floor and find a fuse that turns off and on with the ignition. then buy one of the fuses with the external terminal that you can attach you radar dector power lead to. that i how i did mine but i just made the external terminal from a piece of thin brass shim stock
Bob,
Check to see if the fuse position for the heated seats is active and turns on and off.
If so....Email me and i'll send you complete instructions with pics and a PN for an "add a circuit" to use.
Pat
I tried 4 different auto supply stores, as well as rat shack, and best I could find was the "add a fuse" for the larger atc fuses instead of the atm fuses(won't work due to spacing), so I copied Clem and used a thin piece of brass jammed into the socket along with the existing fuse.
Working ok.
Thanks all.
Working ok.
Thanks all.
I picked up my "add a circuit" from Auto Zone. I guy behind the counter didn't know what I was talking about. Went out to the asile where the electrical connectors where and found it out there. His comment was I didn't know I had that! You pick up a ground and add the circuit down in the passenger footwell. Piece of cake. A little time consuming routing the wire in to it.
On the 1SA, there are 2 hot wires, and both stay hot (altho 1 goes off, then back on once dimmer lights go off when ignition off)...which is why I need the add-a-circuit...don't want the detector to stay hot while ignition is off.
I did find the correct add-a-circuit at another auto zone, so its in now.
Thanks all for the help.
PS...anyone know how to retrieve a dropped fuse from behind the fuse panel under the carpet ??? Not worth tearing apart to get it....
