Dirty Engine
Old Apr 12, 2005 | 10:02 PM
Firedog's Avatar
Firedog
Originally Posted by ufso
Let's make it known that typing skills and techiques "IS NOT" a prerequiste for being a "bull" engineer...sad but true!!!
Hey Sparky...Break out your dictionary for the spelling of "technique"
Hope all is well....Mike
Old Apr 12, 2005 | 11:41 PM
ufso's Avatar
ufso
...okay, and you have to also be able to spell check when filling out your accident reports, better?
Doing well. Just painted my calipers red, ordered the rear SS Insignias and the visor decal. That's it for the car, I hope. Call me at work and tell me when you're gonna bring it to the station so I can stop by and see it.
'Till then,
Sparky
Old Apr 13, 2005 | 12:32 AM
Firedog's Avatar
Firedog
Will do.....
Old Apr 13, 2005 | 12:50 AM
EngineerBill's Avatar
EngineerBill
Default Be careful with water around the air intake
Originally Posted by Scissors
I don't know if this was corrected on the C6, but GM specifically stated that water should not be used to clean the engine bay of the C5. They issed a TSB, as I recall, about a sensor going bad due to corrosion from water finding its way under something in or around the intake manifold.
I can't remember the specifics--perhaps someone else can.
Scissors is right - be very careful with water in the engine compartment - expecially in the air intake area. Getting the pleated air filter all wet is not very good for it, but getting water onto the airflow sensor can damage it permanently and it is expensive to replace.
Its probably better to carefully spray cleaner and wipe the engine compartment down than risk getting water into the intake.
Bill
