Engine Break In Question
Old Apr 13, 2005 | 09:09 AM
Scruff Vette's Avatar
Scruff Vette
Default Engine Break In Question
How did most of you break the engine in during the first 500 miles? I know not to keep it in one rpm range for long periods of time, but did you start slow at first progressing to higher rpm's as you put more miles on, or just went straight for redline from day one?
Thanks for any suggestions
Old Apr 13, 2005 | 09:21 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
i was raining the whole weekend when I got mine. I did alot or backroad and in town driving to break it in. the rain helped me keep my speed down. if you want the engine to last and don't want to burn oil / have high oil consumption you will baby it for the break in. this is when the rings get set, as well as the initial break / wear in of the powertrain.
just keep it slow, don't really have to worry about not keeping the rpms constant if you do the in-town break in.
Old Apr 13, 2005 | 09:43 AM
HOFFIE's Avatar
HOFFIE
I picked up my DSOM,z51 on Saturday from Kerbeck & it took 5 hours to get to Long Island...I was stuck in traffic 1/2 the ride and the other 1/2 of ride I stayed between 50 & 60 mph ...Kerbeck told me to drive it like any other car & not to Baby it.It is 405 hsp..I did get lots of brake dust
Old Apr 13, 2005 | 12:11 PM
lehew's Avatar
lehew
I tried to generally follow GM's recommendations. I figure there are a lot of moving parts coming into contact and getting to know each other (in the engine and elsewhere).
I took it pretty easy for the first couple of hundred miles by driving on back roads at varying speeds. I tried to keep the speed down (not easy) and avoided quick stops. After that, I gradually started driving it a bit more "enthusiastically." I still tried to keep it below about 4000 RPM until I had about 500 miles or so on it.
Now I just drive it like I want to...
Old Apr 13, 2005 | 12:13 PM
Tom/99's Avatar
Tom/99
I break my cars in just like I will be driving it. I don't drive them any special way.
Old Apr 13, 2005 | 12:18 PM
TEAShea's Avatar
TEAShea
There is another recent thread on this with excellent advice.
TEAShea
Old Apr 13, 2005 | 12:29 PM
KDH's Avatar
KDH
Why does the owners manual recommend keeping it below 55 mph? I would think it's RPMs that matter-not speed. Unless, of course, you like to drive at 70 mph in third gear.
Old Apr 13, 2005 | 01:23 PM
mforman42's Avatar
mforman42
In fact, the Porsche break-in schedule has an RPM limit by miles. I've ignored the 55 MPH thing on every new car. I think it is a holdover from the dreaded 55 MPH national limit. Keep the revs out of the higher end of the tach and enjoy.
Old Apr 13, 2005 | 01:33 PM
HARVEY T.GLUCK's Avatar
HARVEY T.GLUCK
Default Break In
HOFFIE: As one of our finest here in NEW YORK.....how are you Handeling the Front License Plate.???..Will have my Vette Shortly..Thanks, Harvey T. Gluck HTG39@AOL.COM
Old Apr 13, 2005 | 01:45 PM
HOFFIE's Avatar
HOFFIE
[QUOTE=HARVEY T.GLUCK]HOFFIE: As one of our finest here in NEW YORK.....how are you Handeling the Front License Plate.???..Will have my Vette Shortly..Thanks, Harvey T. Gluck HTG39@AOL.COM[/QUOTE
I Refuse to mess up my car because of a law...I will carry the front plate with me with the holder..If I get pulled over I will just tell the officer it fell off because its mounted with tape..If he issues me a summons(shame on him)As the NYC vehicle traffic law states,I have 24 hrs to fix the problem & get a receipt if needed(ex:broken tail light,cracked windshield,broken tail lamp,no front plate)and return the car to any NYC Police Pct & have it examined by a police officer.The Police officer will prepare a form & sign it stating the problem has been corrected.I will than mail that form with the copy of the summons & plea not guilty..I suggest you all do the same in NYC as you will get away with it
Old Apr 13, 2005 | 01:55 PM
shopdog's Avatar
shopdog
The main things you're breaking in are the rear gears. That's why speed rather than RPM matters the most. The important thing is to vary the speed so that the gears develop an even wear pattern. If you don't, you may develop a rear end whine. I agree with whoever said that the 55 MPH is just a holdover from the old national speed limit. There's nothing magic about that speed. Just avoid running at constant speeds and heavy loads until the gears have a chance to wear in properly. In other words, keep the cruise control off and your throttle foot light.
Old Apr 13, 2005 | 02:03 PM
KDH's Avatar
KDH
Good info. Thanks!
Old Apr 13, 2005 | 03:20 PM
chadwick's Avatar
chadwick
There was a quote from Dave Hill that said this is exactly what you should do with the Corvette Engine. But someone else pointed out Dave doesn't have to keep the car 100k+ miles, either.
Old Apr 13, 2005 | 05:02 PM
7 OUT's Avatar
7 OUT
Short trips with plenty of cool down periods are also important. Other than that, I didn't worry about keeping it under 55 but did make sure I varied speed and rpm's quite a bit.
Dana
Old Apr 13, 2005 | 05:17 PM
TedG's Avatar
TedG
We used to have a very good discussion in the FAQ. But that seems to have been mostly blown away. The first page is half gone and the rest seem to be history. I seems that the server change has taken it's first casualty.
Old Apr 13, 2005 | 05:41 PM
b4i4getit's Avatar
b4i4getit
The owners manual is largely a cut and paste from other GM manuals. There is a lot of information in the manual that does not even apply to the C6. Don't take the manual as the last word on anything.
Old Apr 13, 2005 | 05:44 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I drove it however I felt like...mostly hard.
To Engine Break In Question
Old Apr 13, 2005 | 05:48 PM
TiVoManiac's Avatar
TiVoManiac
Many of these replies would be hard to follow if you got it at the Museum and drove it home, especially out here to Arizona. Unless you make it a really LONG (slow) trip.
Old Apr 13, 2005 | 07:37 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Follow the manufacturers advice. Keep the speed down, no sudden accelleration (to let the ring and pinion faces wear to each other under light load) vary engine and vehicle speed, and go easy on the brakes the first 500 miles. You have nothing to lose by following the proper breakin procedure. Listen to the engineers, not the car salesmen. And an LS2 is not that different from a truck engine or a V6. There is no majic to the LS2. Just more displacement, more cam, good heads, intake and exhaust. Just because it's got 400 HP doesn't mean it should be broken in any differently.
Old Apr 13, 2005 | 07:49 PM
C6Matt's Avatar
C6Matt
for what its worth I am a powertrain engineer for GM and on this, engineering tolerances are just that, tolerance's. designing, actually machining an engine is done in the real world, and the break in process is about letting all the varing parts get their final machining in the running engine, but its lightyears ahead of where it used to be.
