Ignition Switch Noise
Old Apr 18, 2005 | 06:52 AM
Scruff Vette's Avatar
Scruff Vette
Default Ignition Switch Noise
Is it normal for the ignition switch to make a brief electronic "swawking" noise when the on postion is pressed just before the engine is started? Is it a locking system being turned off?
Old Apr 18, 2005 | 07:54 AM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
I don't know about locking the ignition, but mine has made that noise since day one--Ed
Old Apr 18, 2005 | 08:51 AM
shopdog's Avatar
shopdog
Do you have a manual transmission? If so, what you're probably hearing is the steering column lock releasing. If you have an auto, which doesn't have the steering column lock, then I don't know what you're hearing, but I don't think it can come from the switch. The switch is a simple illuminated rocker switch, nothing in it to make noise.
To Ignition Switch Noise
