Auto Audio Volume Control
I have the 1SB 7 speaker Bose system on a Vert.
Also can't tell that this feature actually does anything at all.
And mine (not NAV) only has On/Off when you press the auto thingy. There's no other adjustment.
When in doubt, read the manual.
C64Lucky
But my AUTO volume does noticeably work.
EDIT: BTW, the next paragraph after the one containing the info. about "MIN", "MED", and "MAX" says that if your vehicle has the Bose audio system, it includes Bose AudioPilot noise compensation technology. It also requires use of the AVOL button. I guess that's what those of us with 1SB and non-Nav have. It compensates for background noise.
So having just looked at the manual and since I have the 6 CD system, I don't have the 3 options of min-max - only on/off. I swear with it being on I can't tell any difference.
If your vehicle has the Bose® audio system, it includes
Bose AudioPilot® noise compensation technology.
When turned on, AudioPilot® continuously adjusts the
audio system to compensate for background noise,
so that your music always sounds the same at the set
volume level. This feature is most effective at lower radio
volume settings where background noise can affect
how well you hear the music being played through your
vehicle’s audio system. At higher volume settings,
where the music is much louder than the background
noise, there may be little or no adjustments by
AudioPilot®.
To use AudioPilot®, set the radio volume to your
desired level. Turn AudioPilot® on by pressing the
automatic volume button until AVOL ON appears on the
display. As you increase vehicle speed, the background
noise in your vehicle will increase. AudioPilot® will
adjust your audio system’s output for the background
noise it hears. To turn AudioPilot® off, press the
automatic volume button until AVOL OFF appears on
the display. For additional information on AudioPilot®,
please visit www.bose.com.
